Results 1 to 13 of 13
    Senior Member Three Rings theboogieman1's Avatar
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Interior Water leak???
    So I noticed that I have water leaking inside the car and not exactly sure where it is coming from. I was hoping someone else has had this problem. It's leaking about 2 inches from the top of the windshield on the driverside a pillar. I was driving and kept thinking I was seeing water drops and eventually saw one drop. I tried to feel if it was wet all the way to the top but it wasn't, only from about 2 inches down and a 3 inch portion below that. I do have water marks on the A pillar now as well. Any idea if this could just be the windsheild that needs to be replaced or is it something with the sunroof? Any help would be great, cause it looks like the rain isn't going to stop for a while.
    02' Black S4 6spd / JHM "Stage 3" / JHM "Solid" Shifter / VAST Stg. 3 Clutch and LW Flywheel / Vogtland GT's / 034 Track Density Motor Mounts/ AWE DTS / JHM FMIC / Hawk HPS Pads / H-sport sways / SSAutochrome TB Exhaust
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Re: Interior Water leak???
    I just went out to check to see if my car was soaking wet after sitting in the rain all day and everything now feels dry. I'm wondering if it's only when I have my wipers on and it pushes the water in through a bad windshield seal or something. Any thoughts?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I would suspect the sunroof before the windshield. Try taking off the head liner and seeing what it looks like in there.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    the drains for the sunroof are known to drain in the car... you can go to autozone/advance auto parts, ect.. and go to the help section... but some sort of throttle cable, or something of that sort, and use that as a pipe cleaner... there are 4 drains, one in each corner... that should take care of your problem
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Mine used to do the same exact thing. I came out one time and found an inch of rainwater in the backseat floor. I later found out it was the boost gauge hose through the firewall that was leaking. I gooped it up with silicone sealant and that stopped the leak.
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Quote Originally Posted by S4 Dan View Post
    I already have a throttle cable laying around just for this purpose. Do you know if there are any pics of where the drains are? I don't have a clue as to where to start cleaning it out.
    May 04 2005
    Connecticut
    Quote Originally Posted by theboogieman1 View Post
    not sure if there are any pics posted... it should be in each corner of the sunroof... id go take pics, but its too dark out there where my car is parked.. take a look IIRC, you can see them when you look into the lip
    2000 Audi A8
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    theres a couple of ways to do this. you would have to take out the rear bumper and the hoses are along the sides (write up on AW)
    i found out that u can just take off the cover for the 6 cd changer and pull out the hose form there and stick the throttle cable threw there and pull the carpet on the other side and the hose should be right there. that would help if you if you wouldnt want to pull your bumper off
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    great, thanks guys! I'll look up the DIY on AW and look around so I don't have to take the bumper off. I was noticing yesterday that with my sunroof on tilt it seems to have a bit of play when going over bumps. I can hear a little bit of moving like it's not sealed right or something. Maybe this could be it as well.
    May 04 2005
    Connecticut
    good luck
    dont think you'll have to do anything with the rear bumper anyway... from what it sounds like the front drains are clogged...
    2000 Audi A8
    Senior Member Three Rings Cyrix9445's Avatar
    Dec 05 2006
    2004 S4, 1995 Wrangler
    Orlando, FL
    Heres the procedure from alldata (for B6, but might be the same for B5):
    Cleaning Water Drain Hoses
    NOTE: For cleaning, it is recommended that you create your own assisting tool out of a speedometer inner cable, approx. 2300 mm (90.5 in.) long.
    1 - Front water drain hose
    Front water drain hoses - 1 - are routed in A-pillar and end between door and A-pillar. Cleaning is performed at cut out for sunroof.
    2 - Rear water drain hose
    Rear water drain hoses - 2 - are routed in C-pillars and end at sides behind bumper cover. Cleaning is performed from lower hose end. To do this, bumper cover must be removed.
    2004 Sauce4
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Sweet! I'll see how accurate these are on the B5. Hoping to try it out today, all depends on work. Thanks!
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    So after going out of town in the rain I found that the leak was a lot worse when driving. I started to think that it was my windshield that was leaking. I got even more confirmation on this on the ride home, I was noticing a lot more wind noise coming from the driverside than the other. That brings me to today, I ended up getting my windshield replaced cause I had a lot of chips and a big crack. The guy who replaced it said it was my windshield that was leaking really bad. I guess the primer on the windshield was bad and water was getting in easy.
    So I'm hoping this is the only place it was leaking, just wanted to give an update incase someone else is having the same issue.
