Results 1 to 6 of 6
    May 09 2007
    jersey
    please help. coolant problem
    i have a huge coolant leak. (see pic below), Right next to the injectors there is a coolant hole that goes to the back of the engine bay. it is held in place by 2 10 mm bolts that go on top and bottom of the metal holes. is there a gasket that i missed, please help.
    [IMG][/IMG]
    Senior Member Two Rings tonelee1316's Avatar
    Oct 11 2006
    rancho cucamonga
    Re: please help. coolant problem
    yes theres a o-ring that goes between the water pipe and the coolent flange
    Genesis Autosport
    Evolution Racewerks
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
    the sealing o-ring thats like the 15th item down.
    May 09 2007
    jersey
    thanks everyone
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    hey thats my engine bay!!!!! lol...hopefully you`ll get coolant leak problem solved!!!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    May 09 2007
    jersey
    lol thanks for the pic. lol
