Results 1 to 12 of 12
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Cupra Lips in Winter
    I'm thinking about getting a Cupra lip, but I'm a little worried about how these things stand up in the snow living in Canada and all. For those of you with Cupra lips, how are they holding up? any problems? Also, how easy are they to install, Do they just screw in to the bumper or do they use 3m tape, how exactly is it done?
    Thanks for your help
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Cupra Lips in Winter
    if you bolt that baby on with a lot of screws like the OEM DTM splitter, it won't come off easily but I do understand your concern
    Jun 02 2008
    Victoria, Canada
    Do you know if they come pre drilled?
    -Cam
    Old: E92 BMW 335i
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I dont know
    Veteran Member Three Rings kharsnett's Avatar
    Oct 24 2006
    Indianapolis IN
    i also was wondering how these are installed
    B7 A4 Non sline Sline Edition, High flow fog light holes, Titanium license plate screws, Cross drilled lug bolts, greasy axle, Coolant relief valve on cylinder head, Pressure relieving boost hoses, Cylinder Head Exchange program, Custom cam grind, used fuel pump follower, variable geometry front Control Arms, Automatically shifted manual transmission, 87 octane APR tune, detuned 83 Octane APR tune, Custom high flow Flex section, Custom built spark plugs, Ebay sponsored!
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    No they don't come pre drilled and they need to be cut to fit. I did a small write up on how I installed mine. I'm guessing you'd have to do similar things on a B7. Oh and I took it off for winter.
    http://www.audizine.com/forum/showthread.php?t=210863
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    you normally have to shave or cut down the tabs and then bolt them in, I would put at least 3 on each side and 1 in the middle which is 7, others put more.
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    I've had mine through winter so far and it has held up great (Utah). Im putting my car up on the lift tomorrow and if i remember ill take some pictures of how i mounted mine.
    Jun 02 2008
    Victoria, Canada
    Quote Originally Posted by sdjeff View Post
    That'd be great, thanks for your help.
    -Cam
    Old: E92 BMW 335i
    Established Member Two Rings b929's Avatar
    Jun 15 2007
    mine is plowing great =D
    Jun 04 2008
    RSF san diego
    Here are some pictures.. kinda hard to see exactly but it gives you a picture of how i did it.
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    wait til after winter..i mean..im sure the excessive donuts in deep snow didnt help mine.. but..
    now its just carnage.
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
