Results 1 to 3 of 3
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Rear Sensors from Audi - How Easy is the Install
    So I'm considering replacing my bumper with an OEM version with parking sensors. Any ideas/advice about how easy it is to install? Are all of the needed connections present in cars that weren't factory equipped with them? Also, is there an on/off switch in the cabin? Is there a speaker that needs to be added to the cabin?
    Cool stuff with a little growl!
    Sep 13 2008
    Western Chicago Burbs
    Re: Rear Sensors from Audi - How Easy is the Install
    I would assume its a pretty difficult process given that its an audi. i would think that there is a plug somewhere so it might not be too hard but then again its an audi
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    TX
    There have been posts before about guys who have added the sensors, you don't need to buy a new bumper but you do need to drill into the one you have, after removing it from the car. All it gets you is a series of "beeps"... It's also expensive, if I remember correctly. If you have RNS-E I'd look at adding the rear-view camera instead, that's a pretty cool mod.
