Results 1 to 16 of 16
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    Transmission fluid
    Is it ok to run any other kind of trans fluid in the tip cars other than that crap audi calls for?
    Jun 24 2008
    E46 M3
    Woodinville WA
    Re: Transmission fluid
    NO
    That crap is actually pretty good stuff
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    ^^ what he said..
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Jun 01 2008
    Apopka, FL
    ^^ what they said;
    the 'crap' audi uses is better than Mercon V and Dexron VI, which are *brand new* fluids.
    Mar 24 2008
    Illinois
    I hope this stuff is good. I spent $100 for 5 bottles, damn stealership.
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    ze germans know their fluids. either that or they just want to make it so you have to buy their fluid. at any rate if you put anything else in there you will be sorry and it will cost you more then the correct fluid would have.
    Mar 24 2008
    Illinois
    i just hope the parts guy gave me the right stuff
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Looks right
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by arorem View Post
    just like Mercon and Dexron products, the newest audi ATF supercedes older revisions, so if it says ATF, you're good.
    Mar 24 2008
    Illinois
    ok cool, thanks. I was looking at using redline atf, but i was worried it would mess up the trans.
    Jun 01 2008
    Apopka, FL
    as long as it's changed it dosen't really matter for solenoid transmissions at these power levels.
    Mar 24 2008
    Illinois
    so i didnt really need the expensive stuff? as long as i keep up on regular maintenance it doesnt matter?
    sorry, im kind of a noob when it comes to audi trans.
    Jun 01 2008
    Apopka, FL
    Use the Audi fluid, you don't need anything else unless you have a level 10 built trans.
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    I spent $90 on 3 x 1L bottles for my manual tranny. Don't feel to bad.
    2012 Audi Q5 - Daily (slow AF)
    2013 Mini Cooper S - sold
    2005 BMW 325Ci - sold
    2007 BMW 335i - sold
    2004 VW Golf TDI - sold
    2004 Audi S4 V8 Cabriolet - sold
    2003 Audi A4 1.8T - GT2871R - sold
    2000 GMC Sonoma - sold
    1992 Dodge Stealth RT - sold
    1991 Chevrolet Beretta GTZ - sold
    Mar 24 2008
    Illinois
    ^^ DAMN!!
    Jun 24 2008
    E46 M3
    Woodinville WA
    You say you got 5 of them containers...eh
    you will need 7 to do a service on that transmission
    BTW, don't feel so bad, the newer 6 speed automatics take a fluid that costs about 70 DOLLARS per liter and they also take about 7 liters.
    First time I put an estimate together fo a tranny service on a C6 chassis and it came to just barely shy of a grand to do a service on that thing. And the fluid is a weird blue color.
