Results 1 to 21 of 21
    Senior Member Three Rings S4NORICE's Avatar
    Dec 10 2008
    2001.5 S4, Factory Five MKIII
    Clifton Park, NY
    How does the ESP behave on the S4?
    So I've been looking for a B5 S4 for a while now. Can someone please explain why the 2000 models are better without the traction control, or ESP? The only quattro that I have ever driven in the snow was a 98 A4 2.8 without traction control, and the car was completely bad-ass in the snow. I'm buying a 6spd for sure, I live in upsate NY and will be driving the car in snow.
    I'm not a fan of traction control systems on any car, but I've found that some are OK, while others just flat out suck. Some cars that I've driven with traction control completely cut off power to the wheels once they start slipping. I hate this... Does the ESP on the S4 behave like this? This really sucks in situations when you need the throttle to keep from getting stuck, or when your heading toward that snowbank...
    Also, If you turn off the ESP switch on the dash, does it completely turn off the traction control? Again, I've driven cars that cut power to the wheels even when the traction control is turned off (G35 coupe).
    As of right now, I am only considering 01.5 model year or later. However, I really don't want to be disappointed with a quattro car with an overly-sensitive traction control system. That being said, I'd really like to hear some feedback from people that have the traction control and drive their S4's in snow.
    Thanks, I appreciate any insight on this topic.
    -Steve
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    Re: How does the ESP behave on the S4?
    most folks with traction control turn it off the second they get in the car... which i believe completely dissables it.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Established Member Two Rings ashrafnisar's Avatar
    Sep 30 2008
    2001.5 Santorin S4 6MT
    Mississauga, Canada
    In my Canadian 01.5 S4, the ESP hasn't kicked in much, but the few times it has it just seems to be braking the necessary wheel, and quite lightly at that. I haven't gotten far enough out of line for it to cut power or anything. Also, when I turn off the ESP, the ABS system does stay active which I find fairly useful in snow.
    Dec 10 2008
    Clifton Park, NY
    ^^^ Thanks, That's what I was hoping to hear.
    Aug 06 2008
    Canadia
    unless your the stig, your better off with it.
    my S4 has no ESP, even with snow tires, you gotta stay alert as the car dosn't give you much feedback on whats happening.
    the B5 S4 is like the mafia... there is only one way out!
    Active Member Two Rings jlyv3845's Avatar
    Jun 12 2007
    Massachusetts
    you're fine without ESP. and yes it completely cuts out when you disengage it and you will undoubtedly spin the wheels a little in the snow...but in my opinion it's safer to drive with it off since if you do hit a corner too fast you can at least try to power through it and basically drift. this is my third winter with mine and it's almost a better bet to try to power through (if you find yourself in such a situation) than trying to brake if you head in too fast. Since ABS will engage almost instantaneously you'll just end up sliding in the same direction of that telephone poll on the side of the road. right now i'm driving without ABS and ESP since the ABS module has gone on permanent vacation with two summer tires on the front wheels and i still feel like the car drives better than it did last winter with all those systems on. i have an 01.5 and to be fair these cars handle fairly awfully in the snow but they can get through pretty much anything, as long as you're going a reasonable speed. they have no trouble but just don't hit the throttle too hard or you'll just hopelessly spin the tires.
    Sep 30 2008
    Mississauga, Canada
    Quote Originally Posted by jlyv3845 View Post
    I thought I was being overly critical when I first started driving in the snow, but I guess it's not just me. I found it can get through anything, but it's not very precise, tends to pull either way in some snow if you're doing anything over 50km/h. Still much better than my previous car so I'm not complaining at all...
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    you can still power through/drift corners with ESP on. not as well,but just enough so that when you slide sideways through a corner,it helps straighten the wheel afterwards. i keep my ESP on in the snow when im just driving somewhere. it helps because it alerts you by flashing the TC light on the dash when youre sliding a bit. when i turn esp off and slide a corner,the car will kick back the other way and you hafta rip the wheel side to side to straighten it out.
    when my ESP is off,my ABS is off too (dont know if thats normal but it is) and i hate ABS.
    does ESP have anything to do with fuel-cut? because on the highway today,window down,snow covered ground,i was listening to the exhaust (straight pipe,very loud) and when i put it into boost the exhaust sounded like the ESP would cut fuel delivery...could just be my imagination.
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    who says it handles awfully in the snow? i believe me being able to do donuts around people or turn corners using throttle means handling very well. i'd say it handles better than 95% of other CARS in snow.. dont compare it to trucks becuase, well, it's not a truck
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Dec 10 2008
    Clifton Park, NY
    Quote Originally Posted by EuroSteez View Post
    Nice, Maybe I should have just asked "Will I still be able to drift in the snow with the ESP on." That's kinda where I was going with this whole thing.
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by S4NORICE View Post
    if youre looking to slide corners,obviously take ESP off and enjoy.
    Dec 10 2008
    Clifton Park, NY
    So I take it that the S4 has the same shitty ABS module as the rest of the B5 cars, huh? Damn... The module on my B5 Passat has been out to lunch for about 2 years now... I've replaced it twice over the course of 250k miles. I actually like driving without ABS, however power brakes without ABS working can be a bit touchy.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I can't stand the esp in these cars. When it cuts power it does so in a major way and takes a couple seconds to give it back. I pulled fuse #42 to permanently disable it. You still have abs with this. I've only driven in snow twice in my life so I can't tell you how well it works for that, but in the dry it is pure aggravation.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Senior Member Two Rings nvrfollow's Avatar
    Apr 19 2007
    Silver S4 - Laser S4
    Montana
    I litterally just got back from some nasty driving. I drove from Utah to B.C. to Spokane, WA and then Montana and i feel like a damn ice-road trucker. I've driven many cars in the snow and here is my take on Audi's ESP.
    ESP will save your ass in many snow situations especially at highway speeds. For instance if you coming into a large sweeping turn, hit ice and the tires have no grip to steer, ESP will kick and and do something no driver can do; brake on just one side of the car an hopefully get you pointed back in the right direction.
    If that happens without ESP on and your in 6th your not going to be able to downshift quick enough to initiate drift and pull back into the turn. I suppose you could try grabbing the the parking brake, but I dunno I haven't done too many 6th gear drifts.
    Generally I turn it off when I'm driving on snow in 3rd or lower.
    Unless your passing on a strait then i turn it off in any gear, because quattro will actually keep you pointed much more strait with ESP off when your spinning all 4.
    All in all if your going around icy turns in high gears leave it on.
    BTW Audi's, ESP or no. fucking own every other car on the winter highways. Safe travels everyone.
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    ESP = good idea for daily driving, and is not annoying or constantly engaging unless you ask for it or hit a really slippery section. Manageable. Still can have limited enjoyable short slides. Won't really help OR hinder traction off the line much, just prevents the excessive wheelspin.
    ESP OFF = fun/goofing around, longer slides, and more for if you know the car's limits and are comfortable with it on the street. Not a big deal really though, I find the car quite predictable overall with ESP off. ABS should still be present.
    Because I find it unintrusive, and plus you just never know what kind of emergency situation you might run into, I usually have ESP on when daily driving. If I want to goof around, i'll switch it off for a bit.
    All boils down to driver skill and not being stupid on busy public roads etc though.
    Brilliant Black 2001 S4 - 6MT <3
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    A picture speaks a thousand words:
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Dec 06 2006
    09 Subaru Outback XT, JD Tractor, EZ Go,
    Middletown, Ohio
    Wow, 30MPH, straight road, watch out this guys a risk taker.
    Quote Originally Posted by gointoscott View Post
    Established Member Two Rings crosenhahn's Avatar
    Mar 13 2008
    2001 Audi S4
    Colorado Springs
    I live in CO and ski 40-50 days a year... Turn ESP off any time I drive in the snow. You have really Predictable driving in snow with it off. Now for the ABS - it sucks... way way way way too sensitive. But other than that this car rocks in the snow. I always am passing subis (even sti's), saabs, evos and others... Definitely would recommend the car for winter driving conditions. Just watch your braking withe the ABS
    Veteran Member Four Rings fixn2xlr8's Avatar
    Apr 11 2005
    Winston-Salem NC
    Its a true pain in the ass stage 3. I just turn mine off.
    Dec 10 2008
    Clifton Park, NY
    Thanks for all the replies... As long as I have the ability to turn it completely off when I want, I'll be happy.
    I'm hoping (fingers crossed) to be picking up an 01.5 on Monday.
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    there was a thread about this like 2-3 days ago and it was said that with esp off the adaptive braking part of it will turn back on if your sliding and hit the brakes, which is fine with me except sometimes it fights what your trying to do.
    and with esp on it will still drift no prob. but you will not be able to hold it forever like with it off. i love having it off and just doing 2nd gear pulls since its still pretty fast. and people look at you funny when you just take off haha
