I installed my Ecodes last weekend, and I had to rewire the cable going to the housing, since it's not long enough to reach the ecode light. Everything was fine except for the turn signal not working. Then Friday my right headlight went out. The city light works, and the high beam is fine. Just the low beam is out. Between this and the turn signal, I decided to pull the light out today and play with it. Well, I wiggled and played with the wires going to the headlight with everything on, and nothing changed. Took the D1S out and put a spare in, and nothing changed. Swapped the turn signal bulb holder and bulb between sides and the left light works fine, just as it did before. The right is still bad, so I know it's not the bulb or bulb holder. I even swapped my US xenon headlight back in and still no joy. The only thing I can think of is that I've either screwed up the wiring, which worked immediately after I installed the lights, or the ballast has gone bad. I have also been getting serious fogging in the right headlight. Now I'm gonna have to take it to a shop to get the problem sorted out, and I work nights, so I'm sure I'll get pulled over for having a light out. I really can not figure this out...
