Results 1 to 15 of 15
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    H&R sport springs on KONI FSD's
    will it work? i have Koni FSD's with Eibach sport springs, and i want to go a bit lower, will the H&R sport springs work on it? or do you guys think its not such a great idea??? let me know!
    2004 Audi A6 2.7T
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: H&R sport springs on KONI FSD's
    Yes
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Registered Member Three Rings m-avant's Avatar
    Aug 05 2007
    cars with wheels...
    Californication
    I would check with Koni USA - I have only seen recommendations for sport springs or Eibachs pro-kit as a match for the FSD.
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    old Avant (missed dearly) :2000 A4
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    I still think you have it backwards -- change the shocks to sport (Bilstein -- Koni yellow a bit harsher?), keep the Eibachs. But if you're determined to get lower, H&R sport springs are lower than pro kit. At least 1/2 inch. (Remember, I was asking you about your pro-kits when I was researching this, deciding on springs, shocks.) If you think your FSD shocks are a little on soft side, do you really want to get lower?
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Mar 30 2008
    Pittsburgh
    yeah, just a little bit.
    2004 Audi A6 2.7T
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    that's what I'm running right now. The only real issue I have is getting into the parking deck at work. If I go straight onto the down ramp, something under the car scrapes just the tiniest bit going over the edge. I have to hit the ramp at a slight angle.
    Sep 14 2008
    Dallas
    That's what I use right now, and I am very satisfied
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    KONI does not approve of the combination as it kinda negates the purpose of the FSD, which reuiqre more travel to work the way there were meant to. They'll also won't work wiht you if yuo end up having issues. I personally think you'll bottom out/rub in some places and bounce more.... but really it is doable... just with a price.
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Mar 30 2008
    Pittsburgh
    Quote Originally Posted by Gigi View Post
    yeah like $300 for springs and thats it.
    2004 Audi A6 2.7T
    Apr 01 2008
    2010 Jetta TDI
    Frank - I thought it was the "bounce" you wanted to lessen, no?
    Brice -- helluva game last night. I think they'll meet again.
    Mar 30 2008
    Pittsburgh
    the car has to much bounce, and its not low enough , but im not sure yet what im going with.
    2004 Audi A6 2.7T
    Jan 23 2006
    Charlotte, NC
    FSD's will give you that slow bounce but stiffen in harder driving in turns, which is why people get them, while the yellows will be lower and more aggressive therefore harsher in daily driving, over bad pavement.... it is a tradeoff, can't have it all :) Your best bet may be to spend the $$$ and get PSS(, adjust height and dampening til yuo find the right setting. But it is so much $$$ for a car not tracked.
    I think, your car look real nice as is and your ride is still good...
    Wofman, - yeah... poeple are so frustrated... they were hoping :)
    Sep 14 2008
    Dallas
    would you mind posting a LINK to this, because several tuners are selling FSD/Spring combination.
    In addition, could you post to where " They'll also won't work wiht you if yuo end up having issues. I"??
    Also - is this your personal expereince "I personally think you'll bottom out/rub in some places and bounce more."? or is this just conjecture?
    Jan 23 2006
    Charlotte, NC
    Quote Originally Posted by 2.7tDallas/JonD View Post
    I did not say or mean that there will not sell FSD/Spring combos.... I HAVE on my car a FSD/Spring COmbo that came in one box... I was just responding to Frank's questions specific to H&R Springs with FSD's. When I bought mine, the Eibach springs were the only one they sold with the FSD's.
    So the links I would post wopuld be the same you can pull yourself by searching retailers/distributors' sites (I.e.: Tirerack, GMP...)
    post what? I found out by working with my local shop and talking to a Koni person. Just call their number or email them to inquire...
    But if they did not test or approve of H&R springs with their FSD shocks, it is just very likely that they will not work with you and may void warranty if you have a problem on yuor car with that combination. Also like I said, the FSD is built to achieve a specific goal and it needs enough travel to do its job. The FSD is much closer to a stock shock in its behavior than to the Koni Yellow frmo my experience with all 3. And stock shocks, evensport, don't work well with aftermarket springs epecially the low and mroe aggressive ones like the H&R Vs a Eibach.
    Jan 23 2006
    Charlotte, NC
    Experience with three different setups (Stock Shock/H&R - Koni Yellow/H&R - Koni FSD/Eibach) and the stock sport setup, as well as common sense.... soft shock with more aggressive/lower spring on a 4,000lbs car...
    The FSD is very soft compared to other products like Yellows...
    I experienced that bounce/bottoming out with my H&R springs on my stock shocks (SPORT OEM suspension) and I quickly added shocks...
    Are you looking to change suspension?
