    Veteran Member Three Rings GetAudiHere's Avatar
    Mar 06 2006
    Minnesota
    Pulled a code. Any ideas?
    Alright so this code seems to be haunting me. Im at college and it seems to go away if i dont drive the car for awhile, but as soon as i drive it for like 50 miles it comes on.
    P1296 Malfunction in cooling system.
    Any ideas what could be causing this? and how much it will cost to fix?
    Mar 06 2006
    Minnesota
    Re: Pulled a code. Any ideas?
    bump. anyone?
    Veteran Member Three Rings as4driver's Avatar
    Mar 28 2005
    2001 Audi s4, audi a4 avant
    Seeing that im awaiting some help myself i will share with u what i found.
    You need to check or replace thermostat or the engine coolant temp sensor
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    that fault is usually a stuck thermostat. the fault generates when it takes an excessive amount of time for the vehicle to reach operating temperature. i have also seen a vehicle down here in fl that caused it for a water pump, as well as a tt with an inop primary cooling fan (thermostat was also replaced)
    this can also be a faulty coolant temp sender. first, let your car run for 15-20 min or till it reaches op temp in dash. and feel the hose to the d/s of the block under the intake manifold, where the thermostat is.. if it is cold and your other coolant hoses are hot, its thermostat. b5s are not electronic unlike b6's, so it is cheaper.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Quote Originally Posted by B5A4Kevin View Post
    yep.
    those are your two culprits. pretty east fix and fairly inexpensive
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
