Results 1 to 11 of 11
    Veteran Member Three Rings nealRlett's Avatar
    Nov 27 2007
    B7 S4, '71 BMW R75/5
    B7 S4 Stereo in an 02 A4?
    Is this possible? Have a factory symphony II stereo from a B7 S4 and need to put it into an 02 A4. Is this possible? Has anyone done this? If so, what harnesses/ adapters would I need?
    thanks-
    Jun 08 2008
    Calgary AB Canada
    Re: B7 S4 Stereo in an 02 A4?
    im confused. you have a symphony II to put in?
    thats what 02's came with aswell isnt it?
    do you mean the II+ with mp3 compatibility?
    yes its been done, check over in the telematics forum
    Dec 25 2004
    Earth
    Nov 27 2007
    Just the basic symphony II. Came factory in my B7 S4. Need to find out if I can install it into a 2002 A4. Looks the same size. And from this pic above^ looks like it would fit perfectly. Just not sure about the adapters at this point-
    Dec 25 2004
    Earth
    Well if its a Symphony II, then it will plug right in!
    If its a Symphony II+, then you need an adapter..
    Adapter harness can be had here-
    https://www.euro-parts.us/home.php?cat=263
    Veteran Member Three Rings Shak's Avatar
    A4 B6
    Northern VA
    Symphony II+ is one of the best interior mods you can do -- I love mine!
    2002 A4 Quattro Tiptronic w/ Sport Package
    Mods:
    Cleared Corners; Headrest Mod; Symphony II+; Aero Wiper Arms and Blades; Painted Lowers; RS4 Rear Sway Bar, 35% Window Tint
    Dec 25 2004
    Earth
    Quote Originally Posted by Shak View Post
    2nd!
    Nov 27 2007
    Quote Originally Posted by MikTip View Post
    -nice. Its just the basic Symphony II. Sounds like it will be an easy install.
    thanks for your input. Any chance I will have to VAG-com the car?
    Jun 08 2008
    Calgary AB Canada
    what do you have in the car at the moment? i thought there was the symphony and concert installed in b6s.
    assuming that you want a symphony II im gussing you have an audi concert so you'll need a double din air control unit.
    Veteran Member Three Rings ewytt's Avatar
    Sep 19 2006
    2016 SQ5, 2012 Turbo Beetle
    does it still have indash 6 cd?
    2016 SQ5 || 2002 Turbo Beetle
    Dec 10 2008
    Hm, is there a DIY for putting this
    into a standard b6 (symphony)?
    looks good
    2004 Black Audi A4 1.8t Quattro 6-Speed
