Results 1 to 20 of 20
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    weird bad idle/stalling problems
    I'm having some fun with a vette on 95, WOT doing about 100, and the car stalls out. I turn it back on and its really rough, and shuts off when I give any throttle. I pull over assuming I've blown an IC hose. Take the front bumper off and check all the hoses, they're good. Still the car will start up, idle like crap and then bog down and stall if I try to go anywhere.
    I unplug the MAF and the car works fine. I drive it home, assuming the MAF is done. Swap out MAFs and it doesn't solve my problem. I actually swapped out for two just to make sure.
    I checked my IC hoses again and everything is on snug. I have the hitachi MAF on my 2001.5 with 89,000 miles. I haven't replaced my N75 so some are thinking that's the problem.
    Any ideas? Buddy VAGed it but his laptop ran out of batteries before we had time to store them.
    Any ideas?
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: weird bad idle/stalling problems
    My guess is huge boost leak. I would try tbb see if there is tear there.
    Pressure test car for sure. If its a real rough idle, I would say leak somewhere
    whats the boost gauge say pressure is when idling?
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Nov 27 2006
    Baltimore, MD
    TBB is good, I have a samco one and I checked it.
    The boost is fine when idling but the max I get when driving is like 6psi. I'll try and smoke test tomorrow to make sure that's not the problem, but I've tripple checked all the hoses and they look fine.
    Quattro Kings
    @quattroking
    Jan 29 2007
    08 S4 00 S4
    MD
    It really does sound like you just blew a hose off.
    08 S4- Stock SOLD
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    another thought is to check dv's I know when I had a problem with a dv it woudlnt idle for crap and dashboard lit up like a christmas tree.
    Just a thought.
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    If you want to come down to Pasadena I have a pressure tester and air compressor.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Oct 31 2005
    Ashburn
    I've been trying to do some searches of similar threads to try and find you an answer, but nothing so far.
    also i'm not a big fan of smoke test, it did nothing for me. I think pressure testing with some soapy water is the way to go. if i find any info i'll PM you.
    - Instagram: @Sinister_rs5-
    Nov 27 2006
    Baltimore, MD
    ben has a compressor and a smoke machine. we fill it with smoke and then pressure test. that way we can listen and look for leaks.
    i'm gonna talk to him tomorrow about it and see what i can do.
    Quattro Kings
    @quattroking
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    Good luck dude!
    Nov 27 2006
    Baltimore, MD
    thanks man, heading out there in an hour or so.
    Quattro Kings
    @quattroking
    Nov 27 2006
    Baltimore, MD
    boost leak it was. one of the intercooler pipes had popped off but was still very snug, which was why i and the others that checked them thought they were good. all fixed now so i'm happy.
    Quattro Kings
    @quattroking
    Oct 31 2005
    Ashburn
    Quote Originally Posted by Klum00 View Post
    I told you those hoses were on tight
    Aleast it was something simple
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Yay for easy fixes!
    Have questions? E-mail me.
    02 Imola S4
    VA
    I'll need to figure out something better for the hoses since you're having issues with them poping off.
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    :cough: :cough: thanks ben for finding it
    Nov 27 2006
    Baltimore, MD
    yes, thanks ben you're the man.
    mark - all they need is lips, and apparently you can rent a machine to do that so we'll have to get that when we do yours. to be honest, this was the first hose to come off in a few months after i upgraded the few crappy clamps i had.
    Quattro Kings
    @quattroking
    02 Imola S4
    VA
    I wonder if you can use a tail pipe expander?
    Aug 10 2007
    Annapolis,MD
    Quote Originally Posted by TRANS4M View Post
    thats what i use. i have a crush bender at my shop that has an expander on it, an when i did my IC pipes i just expanded the ends a little so it was real tight.... ghetto bead roller but it works
    gotta be careful tho because the aluminum pipes tear real easy on the expander
    Nov 27 2006
    Baltimore, MD
    that's what she said.
    but yeah mark lets do that. just let me know what weekend you want to get it done and we'll do it...
    Quattro Kings
    @quattroking
    02 Imola S4
    VA
    Guess I'll need to collect the pieces first!
