Results 1 to 9 of 9
    Jun 09 2008
    California - Northern Californ
    Replacing Rear Tailight Bulb - sorry if this is too basic a question.
    I searched the "how to", didn't find one on simply replacing the tailight bulb after getting the warning light that it's out - left rear. Owner's manual (2005 S4) actually says to take to dealer for replacement. I know probably not to touch xenon bulb replacement in front, but rear taillight bulbs?
    Anyway, I uploaded a picture of the rear bolt/screw you see that appears to hold in the left taillight assembly in my "photoalbum" - http://www.audizine.com/forum/album....694&pictureids[]=2337&pictureids[]=2338. If you simply unscrew this bolt, does the assembly pull forward and provide easy access to replace bulbs?
    Can you get the replacement bulb at Kragen or autozone, or is this a "dealer" part like the front wiper blades? Thanks in advance.
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Re: Replacing Rear Tailight Bulb - sorry if this is too basic a question.
    You could get the parts at autozone.the rear bulbs are simple and you could touch them with your hands, but try and wipe them off after they are in so the grease from your fingers don't heat up the bulb too much.
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    wasn't able to pull up your pic but, there is one bolt that holds the taillights on per side. Open trunk, on the side next to your taillight thats carpeted towrads the top you will find a carpeted cap. Use a flat head screwdriver popping it open, just get underneath it and it will come loose. Under that cap is a screw, you can use a philips head for this one. Unscrew it and pull out the screw, might have to use a needle nose to get it totally out.Now, the only thing holding your taillight on is a ruberised guide on the opposite side of the tail light from which you pulkled the 1 screw. Just take both hands and firmly pull out towards you,should come out pretty easy. Once the light housing is off the car there are going to be a set of wires going to the back of the housing.There are two tabs, pull up on them and wiggle the lights out. They (mutiple lights,I think 5)will come out in one big section.Replace the one that is burnt and re-install. Hope this helps. Chris
    Jun 09 2008
    Thankx Monchici, I thought I could just unscrew that screw but wanted to double check since I don't have a workshop manual.
    Jul 03 2004
    Boulder,Colorado
    Quote Originally Posted by akitamike View Post
    Anytime buddy.
    Veteran Member Four Rings B6bomber's Avatar
    Jan 05 2009
    05 B6 S4; 98 Nissan Altima
    LA area, Back in Simi
    heres to hoping that this is going to be easier than trying to get the coins out that were stuck behind my ashtray.
    -Gavin-
    mister_tu - Whoa there buddy! Don't be throwing around rape like it's a casual thing. All my bishes give me consent to violently ravage their vaginas.
    I <3 AZ!
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    Yes, undo that screw and the whole assembly pulls out. BE CAREFUL NOT TO DROP THE SCREW IN THE SPACE BETWEEN THE TRIM.
    You will never see it again, it will rattle and drive you insane if it does not shimmy out and you will be sad.
    “Wanting to be someone else is a waste of who you are.” - Kurt Cobain
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    I will be doing this tomorrow...
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    Quote Originally Posted by Monchichi8 View Post
    great description. thanks!
