Results 1 to 8 of 8
Thread: brake fluid
    Oct 23 2006
    2022 Chevy Tahoe, 2012 Acura MDX
    Houston
    brake fluid
    I have an 2003 A6 2.7 tiptronic
    Where is my brake fluid container? I need to add more to it I think?
    I know silly question but I am not sure where it is.
    Problem: when I make hard right turns my brake light comes on, and beeps 3 times. I am pretty sure I just have to add some fluid to the container.
    please help
    -beck
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Re: brake fluid
    It could be your pads.
    Take a look at the photo. The yellow cap at the top of the pic is where you insert brake fluid.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Re: brake fluid
    After you fill the brake fluid to the "fill line" stick a pen in the brake fluid and swirl it around to release the trapped air below. Then refill the brake reservoir and repeat the process. If you needed brake pads the floowing symbol (0) would have appeared on the dash.
    Oct 23 2006
    Houston
    Re: brake fluid
    TY, TY, TY. I doubt it is the pads cause they are about 10K miles in. and yes they r OEM so I figure I have another 5K more miles on em.
    -beck
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    Re: brake fluid
    yeh i put some brake fluid in there and it stop the stupid beeping
    Senior Member Two Rings Asix's Avatar
    Jan 25 2008
    Audi S5
    Bellevue, WA
    Re: brake fluid
    hey guys, i had the same beeping light problem. I tried filling in some brake fluid and I was only to fill a little bit. Is there a technique to fill it? I had to push down with a straw so the fluid would go downa little more...overlall I probably was able to only fill about 2 oz. of fluid. Any suggestions?
    Thanks guys!
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    Re: brake fluid
    I had the same beeping problem and filling the brake fluid. What is the correct way to top of the brake fluid?
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
    Oct 16 2007
    Brooklyn NY
    Re: brake fluid
    don't think there's a correct way.. just tap the mofo up.... shake the thing to see if you can get air out.....
    C5union NYC
