Results 1 to 16 of 16
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    I get to spend mooore money now!!
    Airbag light came on a few days ago and pulled the code to get that its
    "Internal Control Module Memory" 65535
    After doing some research and using the "SEARCH" button i understand i have to replace this brain. stealership wants a fortune. ECS tuning wants $989 and some people go to shokan...
    when i thought i fixed/replaced everything on the car... haha it never ends.
    is there anything else i can do besides dishing out $400+?
    I did check the connectors under each seat!! didnt fix it of course
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
    Aug 11 2008
    sehg
    Re: I get to spend mooore money now!!
    it's funny b/c my airbag light's been on ever since i picked the car up back in late april..and wondered if you're problem's the same as mine.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    So you need a new ECU? Id check classifieds and AP
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 09 2007
    00 S4
    MA
    keep trying the connectors...unplug and re-plug...wiggle
    I have never heard of anyone actually needing the computer itself...but if you indeed really do need it, A&P seems to be the best place for anything you have to but dont want to buy (stock parts)
    Feb 27 2005
    North Wales, PA
    find someone wos parting out a car. look on vwvortex
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    Quote Originally Posted by biketsai View Post
    i dont think an ECU, but the airbag module like the ABS module that goes out on alot of our cars... at least thats the jist i got from reading up on the same problem. but i could be wrong
    here is the link from ECS to the part i think i need...
    http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
    Jan 25 2008
    Portland
    I just bought a programmer from alpha-bid to clear that exact error on my airbag controller. Worked perfectly, and it was only 50-60 bucks. Look for it on Ebay.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    look under the front driver's seat.
    find the purple and yellow connector.
    open up, and clean connector with electronics cleaner.
    re-connect harness and zip tie it as tight as possible.
    clear codein vagcom and you're good to go
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    ^^^^ Fault is for "internal check sum error" in the airbag module. Meaning the 2 circuit boards inside the module don't see eye to eye anymore and if erased the fault will eventually come back.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Sep 28 2006
    Lexington
    Quote Originally Posted by B5Quattro190 View Post
    My airbag light was on for a while and it was my passenger side seat airbag, and all I did was push the plug in and reset the light!
    It can happen if the push the seat back to far to fast( it pulls out the plug)
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by quattro16 View Post
    i realize that. BUT, when i had my B5, i had like 4 different airbag codes that were all over the car. one being the module. i ziptied the driver's side connector tight and the airbag light(or codes) never came back.
    it's an easy/quick fix that might solve his main problem. might as well try it before spending more $$$$ right.....
    Current:
    Previous:
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    If the airbag light would prevent you from passing an E-Check station, then I would fix it.
    Otherwise pull the bulb and don't worry about it. My "AIRBAG" light has been on since I bought my car. I need a driver's buckle switch and I forget what else. Basically, I just deal with it. As soon as I tried to fix it, the CEL came on. I'll just leave one fault in there, so it doesn't think it needs to add more.
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    ha yeah i did that and the moment i started the car again it came right back on. never went away. i tried all the plugs and re seating them and not moving any seats anymore and it just wont go away. I honestly dont care about the light, but you know, if it was an easy fix id have it done.
    I read the DIY on how to get to it and it looks like i need to take out the radio which i dont have the tools so ill prolly end up making my own and seeing if i run across a used one or maybe someplace can rebuild it? who knows...
    Jan 25 2008
    Portland
    Wow. I gave you the fix for that error a few posts back. You do not need to remove the module.
    Buy this. http://www.alpha-bid.com/product74.html
    Plug into the odbII port. Press erase. Wait 15 seconds while it reprograms your module.
    Save 700 bucks on a new module, the hassle of installing it, and enjoy a functioning airbag system.
    Hell, drive to Portland and I will do it for you.
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    clear the code and see if it comes back, thats what i did when i bought my car 3 years ago with the same code, and it never came back
    ::2002 S6
    Veteran Member Four Rings A4edwin's Avatar
    Dec 07 2008
    01 a6 4.2 sport, 92vw cabriolet, 03 Tahoe, 03 Ford Explorer sport.
    New York
    regardless of what you do you have to clear the codes with vag-com
