Results 1 to 9 of 9
    Veteran Member Four Rings a4_matt's Avatar
    Sep 19 2006
    Wanted: e30 calyso vert!
    Chicago
    road trip questions/tips
    I searched and have some general advice for what to do to my car in preparation for taking a road trip. Change oil, check fluids, align tires, etc... i have Bridgestone Potenza (i think these are them... mine have the same tread pattern, i need to look) http://www.bridgestonetire.com/tires...productID=1080 on my stock sport wheels and it says they would work good in snow. (well i have 3 of them and one got gashed and needed replaced and the tire place said they discontinued them and gave me a tire that has pretty much the same tread pattern. i only had ~500 miles on it before replacing so there isn't a huge difference in the life between the two - had the 3 for ~14 months now). Should i take their word for it and believe them about the snow... they work really well in the rain in Tallahassee.
    Reasons for asking.....My friends and I are going to be driving from Florida to Lake Tahoe during Spring Break, so it shouldn't be as snowy as it was last week (we bought season passes and want to go back but the bus from the airport to heavenly and the heavenly/town bus system sucked balls so were planning on driving). As for the fluids, can i check them myself (i have little car knowledge... my roommate knows some stuff about cars) or should i just go to like Tuffy/Jiffy Lube/Wal-Mart and ask them to check the fluids to make sure they are good for a road trip of that length. I know i'm posting this way far in advance, but i just need to know about how much money i should save to to get my car ready.
    Thanks a lot....
    -Matt
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: road trip questions/tips
    change your oil and coolant and you should be good to go. Make sure your spark plugs are good. And if your car has higher mileage bring some coil packs just incase.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Sep 19 2006
    Chicago
    Right now i have ~73000. I've had all my coil packs replaced w/in the past 2 yrs (since i've owned the car) b/c they have all gone. Where do i buy them, how much are they, and how do i replace them if they go bad? Other than that, sounds good. Thanks
    and TIA for answering the other questions
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    coilpacks: ecstuning.com mjmautohaus.com and etc etc and etc
    or the dealer
    How many miles is your roadtrip??? i would prolly change the oil, get a set of coilpacks
    Sep 19 2006
    Chicago
    ~2600 miles
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    if u know sometheing is wrong with your car, tyr to fix it now, otherwise your should be ok.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    timing belt been done? If you are up on your regular maintenance you are good to go. tire pressure is a big thing for road trips. make sure it is up if you have a car full of people, you'll get better mileage. 38 i think is recommended on the door of the car.
    how long is your spring break? florida to tahoe is a haul. you going to have any time to ski/board?
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Dec 06 2007
    take some decent tools, a can of fix a flat, quart of oil and coolant, some power steering fluid, coilpacks, a knife just in case and ur set
    have u done ur timing belt/waterpump yet? is not do it before u go, mine blew out in the 70s. do an oil change, and coolant flush, check for leaks and ur good to go.
    -Kirk
    BetaAlphaTau Member #58
    Sep 19 2006
    Chicago
    Right now, nothing is wrong with my car, just had my fuel gauge fixed (so they said. I would fill up and it would only read 3/4 full and they said they fixed it so i filled up and it did it again but 5 miles later it said it was full. We'll go through this tank and see. Also, while i was out of town, my parents went to pick my car up and they said the ac wasn't working and the part is on order now, but the ac seems to be working fine for me now... so i dont know. its covered under the warranty i have so i'll just let them replace it.)
    But, yeah, timing belt was done at the 70k service.
    We have March 9-13 (mon-fri) off for spring break, so technically we have the 7-15 off (weekends). We're going to try to get like 4 days of boarding in. It says it will take 1 day 15hrs. We're going to try to leave on Friday and drive straight through and just switch off drivers every like 5 hrs. There's only going to be like 6 of us and we'll take 2 cars. so we'll drive like 5 hrs a piece and relax 10 then switch... and so on..... Board monday - thurs/fri(1/2 day) and then drive back like Fri at midnight or Sat morning or something. We'll play it by ear on the leaving day...
