Results 1 to 20 of 20
    Jun 08 2008
    Calgary AB Canada
    Incorrect speedo?
    I was driving on a highway a while ago and played with my average speed counter in the DIS.
    whenever i reset the average speed, it would jump up to my current speed, but the value on the DIS read about 10km/h less than what the actual speedometer read.
    Shouldnt they be running off the same system? what could cause this
    Established Member Two Rings Torqie's Avatar
    Jul 15 2007
    2003 A4 quattro 5 speed
    Salt Lake City, Utah
    Re: Incorrect speedo?
    Quote Originally Posted by onceover View Post
    Ive noticed that too, but also when I go by those signs that tell you how fast you are going my speedo reads about 5mph faster then what the sign says I am going. I am on stock wheels with 235/45(i think)/17. Going to get winter tires on tuesday though.
    Sep 30 2008
    92 black vw cabby, 91 pearl yellow corrado g60, none of wich are stock!!!
    quebec city, canada
    i dont know if it means anything but ive noticed the same thing, but my speedo is about 10% fast also, so the average speed seems somewhat correct but the speedo isn't (on the cruise running 120kph, gps show 110kph actual speed)
    ps: tires are the correct size...
    is there something that can be adjusted through vag?
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    ^^^me too about 5mph. thats weird
    barrett
    2019 SQ5 Prestige
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    it might be because of your rims if you have any?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Jun 08 2008
    Calgary AB Canada
    nope, stock rims, stock size.
    wouldnt both things get the reading from the same unit? i dont see why not
    Oct 09 2008
    maybe its just me. but i have never seen those speedo things on the side of the road say the same speed as the cars speedo.
    Established Member Two Rings member's Avatar
    Jan 14 2005
    San Francisco
    mine speedo was off but i had 19's from stock 17's
    Member since 2004.
    2020 BMW M340i - 382hp - E-Diff - ZF 8AT -
    Jul 15 2007
    Quote Originally Posted by steezejunky View Post
    with my 97 integra it was right on with those... but maybe it was my teggy was off on the speedo.... who knows.
    Aug 26 2005
    Both displays use the same speed reference, but there is no reason the calibration must be the same. The digital display is more accurate than the analog speedometer. The speedometer calibration is intentionally (required by law,) set with a speed error so that the indicated speed is faster than the true road speed that the car is actually traveling at. I set my cruise control set speed, using the digitial DIS displayed value, not the analog speedometer indicated value.
    Jun 08 2008
    Calgary AB Canada
    really? whats the reasoning behind this?
    Dec 06 2007
    ^^all audi's are the same they always show a 5MPH difference, but that works to our advantage.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    very true. vw's are like that too.. if the speedo says you are doing 70 its more like 65ish.
    safety issue.
    Aug 26 2005
    Supposedly, to avoid the problems that would result if the indicated speed is slower than the true road speed.
    Senior Member Three Rings Agro's Avatar
    Dec 11 2006
    04 A4 1.8T USP FWD 5sp
    San Diego, CA
    I had this issue on my Yamaha R1 motorcycle. I bought this little box called a "speedohealer" It let you dial in the adjustment in percentages. It simply was put in line with the speed signal wire coming from the tranny. I wonder if this is applicable on our car? That is if it is electronic speed wire not mechanical.
    APR K04 | APR Turbo Inlet Hose | ER Sport FMIC | TT225 386cc | Neuspeed Snubmount | VMR B7 RS4 Replica's | Forge 007PA DV | Podi Electric Stepper Boost Gauage | Stern Adjustable Front Upper Control Arms | Valentine 1 Radar Detector | Pioneer AVIC-Z140BH Navigation
    Senior Member Two Rings Sammy7's Avatar
    May 03 2008
    2003 A4 Avant, 1985 320i Baur
    San Angelo, TX
    I've noticed that my speedo understates my speed by abour 5 mph. When I'm not in a big hurry and just driving the speed limit on the highway, I have to remind myself that I'm the idiot going lower than the speed limit and I need to speed up.
    What's the correlation between the speedo and the odometer? Say if the speedo's recalibrated to show the true speed, would it throw off the odometer?
    Dec 11 2006
    San Diego, CA
    Quote Originally Posted by Sammy7 View Post
    The speedometer directly coorellates with the odometer. If you are showing more MPH than you are really going then you are tacking on more miles, same goes for less MPH. This is why when people used to disconnect the speed wire, they would not put any miles on the odometer but they wouldnt be able to tell their speed.
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Quote Originally Posted by Agro View Post
    Wrong. The car knows how many miles you're actually traveling even though the speed is off. On my b7 the millage pairs up exactly with my garmin unit and the garmin shows it to be 3-4 mph fast. When I take the car to 130 mph limiter it says 133-134. It knows how fast it's really going and therefor calculates accordingly. I have compared to mileage to friends cars when going to the same destination and it is the same.
    A speed error is not required by law. Why doesn't Mercedes have to follow this law? Why does the b8 have no speed error? It's juts something thats meant to work to the driver's advantage so they won't find themselves traveling too fast.
    Aug 26 2005
    Quote Originally Posted by NorcalPB View Post
    Maybe "Required by law" is not the correct term for this. However, there are government rules and policies stipulating that in order that speed indicated errors don't cause actual speed to be higher than the indicated speed, a built in error (or offset,) is specified in the calibration settings.
    The indicated speed error offset, does not necessarily effect any other aspect, like the odometer.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Most car speedos read fast.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
