Results 1 to 3 of 3
    Senior Member Three Rings ProJect_*A4*'s Avatar
    Jun 01 2008
    2011 BMW M3 Comp. Package
    Some O2 sensor Questions
    Ive searched the forumns for a bit and couldnt really come up with a conclusion.
    So i got a cel code for a faulty 02 sensor. bank 1 of 2, running too lean. Car is at 103k miles and i doubt that the sensors have been replaced be4.
    Im gonna go ahead and replace both the front and rear sensors so i wont have a clean reading pre cat then shitty reading post cat by only replacing the front sensor.
    Only question i have is going test pipe becuz the cat is getting old. Suggestions?
    German Engineering
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Some O2 sensor Questions
    Quote Originally Posted by ProJect_*A4* View Post
    me is confused :) LOL
    are u asking about 02 sensors or about TP?
    if u live were you have emissions test not only thru OBDII, then you wont pass it. If u are stage 1+ then you shouldn get a CEL from going with TP.
    TP is just a pipi with nothing inside, CATS is a pipe with a "filter" inside.
    Feb 17 2004
    Liberty Hill, TX
    the front sensor is the one that tells the ECU if you are running lean/rich; the rear only tells it if the cat is doing its job properly.
    At 130k miles (coincidentally where I am also), both sensors are definitely due for replacement. Should you opt for a test pipe, you'll need to be running software which can mitigate the CEL you will otherwise get. And as mentioned above, you won't pass emissions testing with a test pipe unless you run software which "fixes" the CEL
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
