Results 1 to 19 of 19
Thread: Wheel removal
    Senior Member Two Rings Doc.'s Avatar
    Apr 27 2008
    Ashburn, Va
    Wheel removal
    Hey guys, do the B6s with sport package come with a certain tool to take off the lug nut covers? I cant figure out how to take them off to get to the lug nuts, since they're so deep in there. And only thing i have in the box is the aligning tool and a little pin (which im guessing is for that purpose, but if it is, i cant figure it out). Thanks!
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Re: Wheel removal
    really long needle nose pliers are the best bet because i didnt have that tool either but just pull em out with the pliers and you'll be good. 17mm for the lugs =]
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Wheel removal
    Quote Originally Posted by gtsingh91 View Post
    x2...i had to change a flat on my sister car. Audi provides this small ring type of tool that takes the cap off but needle nose pliers work better
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    May 24 2007
    Southern California
    Re: Wheel removal
    on the USP wheels, what I did was, I got two nails, bent the tips to a 90* bend, then stick them into the holes in the lug cap and pull away.
    Kyle
    2.0L Revo GTRS Eliminator
    Jun 08 2008
    Calgary AB Canada
    Re: Wheel removal
    yes, theres a tool, it looks like a black plastic pair of tweezers that clip into the cover, works like a charm.
    probably blending in with your black toolkit
    Apr 27 2008
    Ashburn, Va
    Re: Wheel removal
    Yea that was my second option.
    Quote Originally Posted by s42k5b View Post
    I have a ring type tool, but i dont see how i can use it.
    Quote Originally Posted by onceover View Post
    Just double checked, still dont see anything.
    Apr 27 2008
    Ashburn, Va
    Re: Wheel removal
    Wheeewww, i was able to take them out with a needle nose. Thanks guys!!!
    Sep 23 2006
    Houston TX
    Re: Wheel removal
    the ring tool is just to remove the wheel hanger if it gets stuck and too hard to unscrew (end goes through the holes in the plastic wheel hanger). do yourself a favor though and get a metal wheel hanger from Winston or PureMS. My plastic one only lasted 4 or 5 full wheel changes before the threads started to wear out.
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    Re: Wheel removal
    B7 A4 Avant 2.0T 6MT - Arctic | H&R + B5 Perches | JHM S/S + 4:1 Center Diff | Apikol Snub + Rear Diff Mount | Hawk HPS | Tyrolsport Caliper Kit | AWE Exhaust | 034 RSB + Spherical End Links | 19" VMR v710
    Jun 08 2008
    Calgary AB Canada
    Re: Wheel removal
    ^indeed.
    Apr 27 2008
    Ashburn, Va
    Re: Wheel removal
    Quote Originally Posted by 617 Bones View Post
    I notice thats from ECS Tuning, but i cant seem to find that certain tool on their site. Do you happen to have a link for it? Thanks!
    Boston
    Re: Wheel removal
    http://www.ecstuning.com/stage/edpd/...ro&engine=1.8T
    Try this link... if it doesn't work search for "Wheel Removal" and you will see it under TOOLS.
    Watch out those... it's a whole $2.60
    =P
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Re: Wheel removal
    you should have had one of those tools included in your tire changing kit
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Re: Wheel removal
    Quote Originally Posted by martini View Post
    I didn't have one of those but a little key ring type of thing to remove the cap. Made changing the wheel a lot more difficult than it needed to be.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Established Member Two Rings audimcnasty's Avatar
    Jul 20 2008
    black B6, white Q5
    chicago
    Re: Wheel removal
    ^ my kit didn't come with one, but i managed to get the covers off with aforementioned needle-nosed pliers when i had a flat tire.
    i have since removed and trashed all of my lug covers. since the lugs can barely be seen, those covers are just a nuisance....but i know that people paint them...meh.
    - eddiemcnasty
    Sep 23 2006
    Houston TX
    Re: Wheel removal
    Quote Originally Posted by Charlescrs6 View Post
    see my post above
    Apr 27 2008
    Ashburn, Va
    Re: Wheel removal
    =P
    Hahaha, i will probably end up paying more for shipping than the item itself :P
    Thank you though!
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: Wheel removal
    I just made a lug cover puller out of tweezers.
    Boston
    Re: Wheel removal
    Seriously, you can make one out of 2 popsicle sticks, a rubber band, and a small file...
