Results 1 to 17 of 17
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    Thumbs down Cold weather and leaky injectors!!!?? :(
    Well we are getting a nasty cold spell here right now and the temperature has been -30 to -34 CELCIUS!!! yep damn ass cold!!
    anyways today i start my car to warm it up and i smell gas so i pop the hood and the injector is leaking gas all over the place.. not super fast but its leaking!!
    the engine warmed up and the leak stops and all is fine
    i'm thinking because its so damn cold the O-rings have contracted causing the leak..
    should I replace the injectors or buy new O-rings?
    car is an 01.5 stage 2+
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Jan 07 2006
    S3%2C%20Q8
    Re: Cold weather and leaky injectors!!!?? :(
    anyone??? bump
    www.eurodrivers.ca
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I have no idea, but fuck Canada is cold. I was bitching when it got 2 degrees Celsius here.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    i would jsut hope it didnt contract and get so brittle that it broke
    Jan 07 2006
    S3%2C%20Q8
    no they just leak when cold.. as soon as the engine bay warms up after even a minute or two they stop leaking and its fine..
    but now my engine bay smells like a lawnmower or something bah! i'm calling my dealer to get new orings for all 6 injectors..
    install seems pretty easy..
    www.eurodrivers.ca
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by lsc2g View Post
    Uhh yeah i would try and get that taken care of. Gas leaking anywhere near hot parts wouldnt have me feeling to safe. Goodluck
    2010 Brilliant Black/Magma Red S4
    Jan 07 2006
    S3%2C%20Q8
    aha yea i'm not driving the car until i replace the orings.. the gas stops leaking after about 1-2 minutes of the car warming up.. if it was leaking with the engine hot i'd be insane to drive= death by car fire lol and 1 sad b5 owner
    www.eurodrivers.ca
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    You poor Calgarians. Although it did his -23C this morning with the windchill here in Toronto.
    Established Member Two Rings ashrafnisar's Avatar
    Sep 30 2008
    2001.5 Santorin S4 6MT
    Mississauga, Canada
    Quote Originally Posted by CONTROL ONE View Post
    -26 last night with windchill. And me attempting to take off my headlights... Didn't work out so well.
    Feb 17 2008
    Ottawa Ont.
    nm. i read it wrong
    Senior Member Two Rings S_four's Avatar
    Dec 13 2005
    2013 Sierra, 08 Grizzly
    I had and still have the same problem with my car. This happened to me last winter. I went to the dealer immediately and bought orings (some ridiculous price too.) Replaced them all myself in a really cold garage only to have the same problem reoccur. The next day I flatbedded my car to a shop and they could not duplicate my leak. Then again this year it's happening again. Maybe if I had done the repair in a heated garage the rings would have seated properly. I dunno. Havent had any fires yet. *Knock on wood. haha. Hope that helps somehow.
    01.5 S4
    3L GT || R8 Reps || Vogtland Coilovers || Some other stuff too
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Make sure you lube the oring when installing otherwise they can be damaged when pushed into the fuel rail. Your new orings might have been damaged. The fuel leak could also be your fuel inlet line. Sometimes they leak at the crimp when it's really cold out.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Jan 07 2006
    S3%2C%20Q8
    installed 6 new orings today.. put some fresh oil on them.. install was pretty easy.. a bit of a pain on the passenger side with little room with all the hoses,etc in the way..
    started it up and no leaks! woot woot!
    now to install my rs4 ICs and timing belt
    www.eurodrivers.ca
    Established Member Two Rings jay340S4's Avatar
    Oct 03 2008
    2000 Audi S4, 2009 Dodge Ram 5500, 2002 Toyota Highlander
    Prince George, BC, Canada
    I was having that same problem with mine s4. It was -34 c here in northern British Columbia and I went to warm up the car the other day, and all I could smell was gas. But hey now I have an idea where to start looking. But same thing once it warmed up, it was fine, no smell.
    Jan 07 2006
    S3%2C%20Q8
    yea.. easy fix.. took about 30 minutes.. leaked on me today once i boosted until i found that one of the fuel rail bolt/screws wasn't done up tight enough so a 2 minute fix did some hard driving and 0 issues
    i'll see what it does if it hits -30 again this winter again.. i hope it doesn't leak thats kinda scary
    www.eurodrivers.ca
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    did you have a problem starting your car?
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Jan 07 2006
    S3%2C%20Q8
    no.. when i installed the new orings gas shot out of all 6 and i realized you need to take the gas cap out and it will relieve the pressure..
    once reinstalled.. i just turned the key to acc.. and then waited 10 seconds and started it and it was a bit rough for a second then was fine
    www.eurodrivers.ca
