Results 1 to 17 of 17
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Red face drivers door stuck?
    As the title subtly hints, my drivers door wont open. It is stuck from the outside, but I can open it from the inside.
    When I pull the handle (the outside handle) its as if the door is locked and won't move. I just feel like I'm about to rip the door handle off.
    The only way I can open the door right now is to climb in from another door and open the drivers door from the inside. Yes, its quite awkward.
    Anyone got any ideas/tips/tricks/solutions?
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: drivers door stuck?
    Its really weird....this happened to me last week randomly.....couldn't get into the car. Had to climb in from the passenger side. But about an hour later, it just STOPPED happening, and hasn't happened since. I drove around for about an hour, and things were back to normal.....real weird tho
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    does your car stay outside?
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    Quote Originally Posted by grAh4m View Post
    haha i dunno why i found that so funny. dude you could also unlock the door with your key and hold it until the windows open, then just reach in and open the door with the inside handle, until you solve the problem
    '17 Ibis White B9 A4 quattro P+ S-Line
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by CruzS4 View Post
    Why thank you for the comment.
    As for the window idea... I never thought of it. But doesn't that roll down ALL the windows?
    Anyone have any other solutions?
    And yes, the car lives outside. My garage was built for car's from the 40's and 50's (aka its little).
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    ^ or throw it on VAGcom and have the windows open with the remote
    May 31 2008
    New York
    I thought most cars of that time were alot bigger
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    So I tried the window trick. Only my front passenger's window opens. In case you aren't a rocket scientist, that means the windows are frozen.
    So with that new evidence. Do you guys think the outside handle door opening mechanism is frozen?
    Mar 01 2007
    WK2
    I just went and bought a case of beer and went to open my trunk and it was frozen shut. i think your above post is a strong possibility
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    I would suggest its frozen as the entire north east is covered in snow and below freezing. Or like what happened to my driver side door handle actually broke the hook thing that pulls the rod that goes into the door. Guess sliding into the side of another car can do that. But I would think water is in ur door lock and froze.
    Time to get the hair dryer out and warm up the handle.
    Jun 14 2007
    2000 S4
    Connecticut
    graham, handle is deff frozen... this happened to me the other day i felt like i was going to be holding my door handle which would be my luck but it finally broke loose... these cars allow a good amount of water to seal up at the bottom of the door sill and its a bitch in the cold. that's why i have my car locked up in the Audisport car condom :) haha
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    This can happen in warmer weather too, somewhat common...the latch or something...?
    Try pulling the handle up gently a few times in a row, sometimes it catches the second or third time.
    Brilliant Black 2001 S4 - 6MT <3
    Established Member Two Rings m4tt VIII's Avatar
    Mar 11 2007
    2004 Evo VIII
    Greenwich, CT
    If I'm correct, some of you think the door is frozen closed, or are you talking about the handle?
    You guys have no idea how annoying no driver's door handle is.
    EDIT: this is grAh4m at my friends computer
    2004 WW Evo VIII SSL - 2001 Cactus 6 Speed S4 Avant
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    bring a hair dryer out and heat it up, see what happens. Had to do it to a friends car the other day and it worked.
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    lol this happened to me last night, it was from the cold weather, only did it once, had to open from the inside, but after the car warmed up things were fine
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Gentlemen. I have an urgent and horrifying news story.
    My door is unfrozen.
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    this happened to me last night also.. its cause it was sticking....
    its called east coast winters.
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
