Results 1 to 8 of 8
    Senior Member Two Rings BryMFL's Avatar
    Apr 20 2007
    '02 Audi 1.8T Quattro
    Winter Haven, FL
    Question How to time new cams?
    Need to time my cams going back on my head after machine work is done. Can anyone shine some light on how to do that?
    "BryMFL"
    Bryan Meeks
    "Quattro- It's like having your very own roller coaster ride!"
    May 24 2007
    Southern California
    Re: How to time new cams?
    damn I just read this yesterday searching around for fun. Both arrows on the sprockets need be pointing up and there needs to be 16 pins on the chain. I think it was a post from a4tschuss.
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    If you have never done it before I highly recommend you pay someone who has to do it. It could be a big mess if you screw it up.
    Apr 20 2007
    Winter Haven, FL
    bump
    "BryMFL"
    Bryan Meeks
    May 24 2007
    Southern California
    Kyle
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    there is an arrow on each cam bearing cap and there are key ways (a notch) in the cam. The arrow and notch have to be lined up and there needs to be 16 links(pins w.e) on the chain between the 2 cams, you'll know when it's right when you put the cam gear on and valve cover on and it all lines up. shouldn't be hard to do. are they adjustable cams or nething? what kinda cams?
    Apr 20 2007
    Winter Haven, FL
    Thanks everyone!
    "BryMFL"
    Bryan Meeks
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by njm23 View Post
    You beat me to it! You figure out your lifter issue?
    The arrows depict TDC for cylinder number one. You set up the exhaust cam first and then set up the intake cam (also arrow in bearing cap aligned with keyway in cam... for OEM cams) and make sure you have 16 pins on the inter-cam chain between them.
    -Doug
