Results 1 to 16 of 16
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Body work Guru's
    This coming spring I will be installing my S4 sideskirts along with couple other exterior bits.
    Now, I am trying to put them on with quality as well as budget in mind. The painting will be done by a very well established/trusted body shop so quality will be guaranteed. Now here is where I am torn.
    I still need to purchase some S4 lower door moldings. So here is my question.
    Would it be cheaper to take off the current lower trim, grind off the clips, and install the sideskirts that way or just buy the expensive trim and install the sideskirts that way.
    Keep in mind my A4 is Santorin so they might have to paint more then just the lower portion of the door. Any help is appreciate.
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    Re: Body work Guru's
    shave all the trim
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    any good write ups on this anywhere? with pics possibly? (havent searched at all, just looked at the thread sorry, but just curious if anyone knows of a good diy)
    Oct 20 2007
    Oct 20 2007
    Quote Originally Posted by flynnr View Post
    Your lucky Im bored at work
    http://www.audiworld.com/tech/ext47.shtml
    Keep it on the subject please.
    Oct 06 2004
    Minnesota
    If you grind them off you will need to re-paint your whole door. Well worth it IMO
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Oct 20 2007
    Quote Originally Posted by A4Rob View Post
    I agree with you but repainting 4 doors in Santorin is not cheap.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by VTAudiA4 View Post
    I did it on my B5 it was BB and cost me like $300 for all 4 doors
    - Clint
    Oct 20 2007
    Is your car Santorin?
    and
    How much of the work did you do yourself?
    Oct 06 2004
    Minnesota
    If you are doing the grinding and smoothing yourself, you better know a painter. Most painters will not paint over someone elses body work.
    Instagram r_michals
    Oct 20 2007
    Yeah I can totally see why.
    I would not do any of the work. Ask me anything mechanical and I will fix it but when it comes to body work I am clueless.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Id call around and get some quotes. It is well worth it. But it might be more costly at times.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Connecticut
    Here's what it'd look like if you shaved the lower part of the door... unfortunately it's on silver! And with Rieger V1 sides. I don't think it'd look right if you did the S4 skirts without the lower door moldings... but I have to confess I've never seen that combination. Good luck.
    01 a4 1.8tqm, giac x, borla, h&r sport
    7.66 CAPS
    Oct 06 2004
    Minnesota
    Quote Originally Posted by kjgarreau View Post
    Ever seen my car?
    Instagram r_michals
    Connecticut
    Nope.
    Better keep it on topic though or VT will murder both of us :) Shoot me a PM, I'm interested to see that combo - thanks!
    7.66 CAPS
    Oct 20 2007
    hahaha.....rob post some pics (like I haven't seen a thousand already...whore ;))
    I really want to do it but I need to keep cost in mind.
