Results 1 to 31 of 31
    Active Member Three Rings 4inchMAF's Avatar
    Sep 04 2008
    Columbus O-high-O
    anyone swapped to A8 front brakes?
    how hard was it? what all is required from the A8? any special tools needed?
    ill be doing some road coarse stuff this spring and, for reason, i dont think the stock A4 brakes are up to the task.....
    thanks for any input
    Dec 05 2007
    Re: anyone swapped to A8 front brakes?
    TT carriers, A8 Rotors, and stock calipers. Many people have done it. Someone should chimme in soon. I know djwimbo did it.
    Feb 27 2005
    North Wales, PA
    takes 30 mins with air tools. just swap rotors and carriers
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Yep, I did it. I'm still very happy with it. My only regret is not doing more research on brake pads before hand.
    Another option down the road if you want to upgrade even more is the Porsche Boxster 4 piston calipers. I have a set if you want to skip the middle portion.
    Stock Swing wheels
    Feb 27 2005
    North Wales, PA
    what pads are you running?
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    took me a while, because i had to wait for the A8 driver to slow down enough for me to get the front wheels off.
    Veteran Member Three Rings Sigma 3's Avatar
    May 23 2005
    Tricities Wa
    [QUOTE=djwimbo;3178634]Yep, I did it. I'm still very happy with it. My only regret is not doing more research on brake pads before hand.
    Stock Swing wheels
    [/QUOTE
    What does this set up cost? (calipers rotors and tt carriers)
    TIA
    Originally Posted by FNK re getting more power from a 2.8 a4
    "Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    ^^^ from what i have read, you're retaining your stock calipers and just bumping up to a bigger rotor and then you need to look for pads.
    Basically the STOCK A4 caliper bolts to the TT Carrier, which gives more clearence for the A8 rotors which are larger than the stock A4 rotors. And then afterwards of course you need some nice brake pads to have the entire shoot-n-match setup
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    any tt caliper carrier or 225s?
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Nov 02 2008
    Boulder & Seattle
    no idea, can someone fill us in on that too? my rotors/brake pads are soon to be shot and need replacement and i would LOVE to bump up to something like this. Is there a written DIY for this?
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Feb 27 2005
    North Wales, PA
    no DIY needed. Its just like changing the brake pads and rotors except now you remove the carries too. There are 2 17mm bolts holding them in. most online retailers sell a kit. its about $350 plus shipping for the rotors and carriers. you just need pads.
    Nov 02 2008
    Boulder & Seattle
    thats great to know. Thanks for the info.
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Poopie View Post
    PBR Metal Master's IIRC. I really want the Carbotech's now.
    They were fine for small course AutoX(and DD), but one track day killed them. There's still a lot of pad left, but they have never been the same.
    The TT carriers should be the same from the 180 to the 225. Both are 12.3" rotors.
    May 23 2005
    Tricities Wa
    Quote Originally Posted by geeky View Post
    Yes but someone posted that the porche caliper was an option in this set up. I was just curious as to how much all the bells and wistles would be
    Where are you at in Washington?
    Nov 02 2008
    Boulder & Seattle
    I'm over in Seattle/Bellevue but make my way towards spokane/pullman once in a while (my home town)
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Sigma 3 View Post
    Depending on what you buy the Porsche Boxster (non-S) calipers for, you can have "Porsche Brakes" for <$400. You can pick up the caliper mounts from PureMS for $175, and whatever you find used calipers for. This is assuming you already have the 12.3" A8 rotors. Otherwise add in the $125-160 for new rotors.
    like I said, for the right price I'd be willing to get rid of my Porsche calipers as they are not installed yet. They are painted black, and shipping would not be included.
    Added benefit is that not only do you get 4 piston fixed calipers, you decrease the unsprung weight of the car, making it faster around a track.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Here's a link to our A8 kit. It's a direct bolt on, and reuses your stock calipers. Install in no more difficult than changing pads and rotors.
    A8 Stage 1 Brake Kit
    Sep 04 2008
    Columbus O-high-O
    so you cant use the A8 calipers too?
    Senior Member Two Rings NK2007's Avatar
    Mar 25 2008
    2000 Audi A4
    Ft. Collins & Colorado Springs
    no, you use the a4 caliper, a8 rotor sometimes refered to as 12.3", and a tt caliper carrier.
    The carriers i got from purems, and when i had it all together, there was a grinding noise when i turned. As it turned out, the new carrier was scraping and grinding down my new rotor .
    Anyway, I had to take it all appart and grind down the carrier in a couple spots, a coat of paint and bolt it all up.
    Note: I am in no way bagging on purems, as they are a great company and i have bought most of my parts through them. It is the fact that the carriers are reproduction ones made by another company. I would assume that unless you buy oem, the carriers are all made by the same company, regardless of who you buy them from.
    I know most people don't have this problem, its just a heads up for those lucky people that do.
    |00 A4 TQM|K04|Revolver Cams|Greddy FMIC|Custom GIAC|Full Custom Exhaust|OEM RS4|S4 Rear|S4 Interior|HID|
    More to come!
    F.S. Rieger Side Skirts in Silver- will trade for S4
    Nov 20 2008
    Harrisburg, PA
    Quote Originally Posted by djwimbo View Post
    Such as this?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by DJSticky View Post
    Such as this?
    Yes, but mine are stripped down, cleaned and painted.
    If you're willing to wait or have a good hookup, you can get them for for less, but it takes time and a desperate seller.
    Feb 15 2007
    marimont
    You can use purems boxster caliper carriers and A8 rotors. Come down to my crib and buy my shiz and I'll install them for you. That is if you'd ever answer your damn phone ;)
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    I like my A8 front setup with B5 S4 rear setup. I been to track a few times, and they work great.
    Front:
    Goodridge stainless lines
    TT carriers
    Zimmerman plain A8 rotors
    PBR ultimate ceramics pads
    ATE super blue fluid (going to switch to something else later)
    Rear:
    OEM S4 rotors
    OEM S4 calipers
    OEM S4 carriers
    IG:@steadysupreme
    Pics&Detail
    Sep 04 2008
    Columbus O-high-O
    Quote Originally Posted by $teady$upreme View Post
    Front:
    TT carriers
    Rear:
    OEM S4 rotors
    OEM S4 calipers
    OEM S4 carriers
    i just so happen to know someone who has a rear brake setup from an S4 that wont be using them.... is there much work in switching the rears to the S4 stuff....
    oh, and solowb5. i just got my phone back. call me ill come down there if you have a garage
    ...for those of you not fortunate enough to live in ohio the last 2 days we've had a wind chill temperature of -23!!!!!!!!!!!!!!!!!
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    the rears aren't a big deal. The major benefit from that is the vented rotors instead of the A4's solid rotors.
    I don't believe install is any more difficult than swapping calipers, carriers, rotors and pads.
    Oct 17 2004
    Columbia, SC
    check out ecstuning.com for their upgrades, if you want to go above the basic kit.
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    For the porsche upgrade, what brake lines do you have to get?? Also has anyone done the S4 rear calipers with A8 carrier and rotor? Worth it?
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    so the pure EMS carriers are bad?
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Nov 02 2008
    Boulder & Seattle
    They are NOT oem, so once in a while, someone will get a lemon, but since PureMS's CS is they'll probably take care of you.
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Mar 25 2008
    2000 Audi A4
    Quote Originally Posted by 47Ronin View Post
    No, like the post above me, I probably got stuck with the one bad set (actually only one of the carriers rubbed). Had i not had a million other issues and just wanted my car back together, i would have sent them back, and i'm sure pureMS would have taken car of me. Instead i just had to file about 1/8 of and inch off in 2 spots and they work perfect now.
    And in all reality the carriers are all probably made by the same company unless you buy O.E.M. from the dealer or off a TT.
    More to come!
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    I went with purems and the install went okay. LINKY w/ pix
    Went with ceramic pads - had to bed them in pretty hard.. But the larger rotors feel a bit better... good luck. Spent about $310 + pads.
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
