Results 1 to 13 of 13
    Senior Member Two Rings Joesturbo's Avatar
    Mar 28 2007
    Lewisville, NC
    Question 1.8T Alternator? Flashing light...???
    So I had some coil pack issues, battery issues and now I am thinking the culprate was the alternator...
    The symptom is this.. Normal acceleration/dirving is ok no problems at all - however once you step on the throttle a little more the battery indicator/icon on the cluster flashes... Let off the throttle and it goes away.
    I am guessing it is toast? Or can I change out the brushes? Or is it re-build time?
    Did a search, but did not find anything that really answered the question...
    Thanks,
    Joe
    2010 A5, 2010 A3 SP, A4 Avant 1.8T 2004, Corrado G60 + 93 VR6, GTi 1.8T + VR6, 65mpg T-diesel Caddy, Jetta VR6
    Mar 28 2007
    Lewisville, NC
    Re: 1.8T Alternator? Flashing light...???
    bump...
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Quote Originally Posted by Joesturbo View Post
    Thanks,
    Joe
    Go get it diagnosed. could be fuel pump or Alt
    Mar 28 2007
    Lewisville, NC
    Ok,
    hooked up my VAG-Com and did a Scope and Log file...
    Voltage at the battery no load and not started 12.6 - on average after this - voltage between 13.3 - 13.5/13.6 - Note this was with AC and headlights on.
    I did not capture the marker when the voltage light flashed and when the check engine light came on directly after... both went away and I tried to reproduce the problem but never could.
    Here is the log info...
    Saturday,20,December,2008,13:03:49
    8E0 909 518 AK ,,1.8L R4/5VT G 0003,
    ,Group A:,'004,,,,Group B:, Not Running,,,,Group C:, Not Running
    ,,RPM,Voltage,Temperature,Temperature,,,,,,,,,,
    ,TIME,,,,,TIME,,,,,TIME,,,,
    MARKER,STAMP, /min, V,°C,°C,STAMP,,,,,STAMP,,,,
    ,0.01,1400,13.580,82.0,60.0,,,,,,,,,,
    ,0.18,1400,13.510,82.0,60.0,,,,,,,,,,
    ,0.36,1400,13.510,82.0,60.0,,,,,,,,,,
    ,0.54,1400,13.510,82.0,60.0,,,,,,,,,,
    ,0.72,1400,13.510,82.0,60.0,,,,,,,,,,
    ,0.90,1400,13.510,82.0,60.0,,,,,,,,,,
    ,1.08,1400,13.510,82.0,60.0,,,,,,,,,,
    ,1.25,1400,13.440,82.0,60.0,,,,,,,,,,
    ,1.42,1400,13.580,82.0,60.0,,,,,,,,,,
    ,1.59,1400,13.580,82.0,60.0,,,,,,,,,,
    ,1.76,1400,13.580,82.0,60.0,,,,,,,,,,
    ,1.93,1400,13.510,82.0,60.0,,,,,,,,,,
    ,2.10,1400,13.510,82.0,60.0,,,,,,,,,,
    ,2.27,1400,13.510,82.0,60.0,,,,,,,,,,
    ,2.44,1400,13.580,82.0,60.0,,,,,,,,,,
    ,2.61,1400,13.440,82.0,60.0,,,,,,,,,,
    ,2.78,1400,13.510,82.0,60.0,,,,,,,,,,
    ,2.95,1400,13.510,82.0,60.0,,,,,,,,,,
    ,3.12,1400,13.510,82.0,60.0,,,,,,,,,,
    ,3.29,1400,13.510,82.0,60.0,,,,,,,,,,
    ,3.46,1400,13.510,82.0,60.0,,,,,,,,,,
    ,3.63,1400,13.510,82.0,60.0,,,,,,,,,,
    ,3.80,1400,13.580,82.0,60.0,,,,,,,,,,
    ,3.97,1400,13.440,82.0,60.0,,,,,,,,,,
    ,4.14,1400,13.510,82.0,60.0,,,,,,,,,,
    ,4.31,1400,13.580,82.0,60.0,,,,,,,,,,
    ,4.48,1400,13.580,82.0,60.0,,,,,,,,,,
    Here is a screen shot of the scope: Note: RED=RPM Green=Voltage
    I am wondering if it could be the wiring or a bad ground somewhere? Also why do you say the fuel pump?
    thanks!
    Mar 28 2007
    Lewisville, NC
    bump
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    before you buy a new alternator, check the ground by the motor mount..if you have to buy one thou I have one that I can sell to you for cheap.
    Some fast things and some slow things
    ~Josh~
    Mar 28 2007
    Lewisville, NC
    OK where is the connection? is it on the passangerside below the turbo?
    Any other ideas?
    thanks,
    Joe
    Mar 28 2007
    Lewisville, NC
    Just an update: Went out this morning - sunny skys return to NC after a week - So no lights on at all and I cannot re-produce the error code... I am thinking it is a multiple issue here: 1. Battery was bad and caused initial issues. 2. It took some time for the ECU's to adapt to getting proper voltage. 3. I don't know if there are grounding issues - but it sure does seem to point to that- Again anyone know where the main grounding points are? My ekta does not have enough information to help me out here.
    Oct 29 2005
    10speed
    San Francisco, CA
    your voltage looks solid as hell on the graph... I would wait until it comes back
    - Clint
    Mar 28 2007
    Lewisville, NC
    ok -was able to re-create at least the misfire... again all 4 coilpacks have been replaced! This is getting on my nerves!
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8E0 909 518 AK
    Component and/or Version: 1.8L R4/5VT G 0003
    Software Coding: 0016751
    Work Shop Code: WSC 63251
    2 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded
    16686 - Cylinder 2 Misfire Detected
    P0302 - 001 - Upper Limit Exceeded
    Mar 28 2007
    Lewisville, NC
    Monday evening bump
    Mar 28 2007
    Lewisville, NC
    bump
    Mar 28 2007
    Lewisville, NC
    Ok final update with the resolution incase anyone searches in the future...
    After a week - I have scanned the ECU again and everything is working properly again... It appears that I had two spark plugs which were fouled. They were an experiment that I was testing with Pulstar plugs. They worked great for about 6 months, but have faltered and caused major pain. I am guessing with our issues with the coil packs that these are just incompatable.
    So I can continue my investigation with a negative for newer cars vs. these things are great for older non-obd2 cars. Either way, they did work very well and gave better MPG for the period that they worked.
    Joe
