Results 1 to 10 of 10
Thread: Codes...
    Veteran Member Three Rings B5in's Avatar
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    Unhappy Codes...
    Would any of these codes be causing my boost to keep getting cut off under load? Also it only happens when I am in my 93 oct. program, not in the stock program, I am still yet to try out my 100 oct. program. I've got GIAC 3 program ecu.
    some specs:
    2001 2.7T
    tiptronic
    TBB, accordian, and all other boost hoses have been inspected & are good.
    16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
    P0421 - 35-10 - - - Intermittent
    17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
    P1131 - 35-10 - - - Intermittent
    17887 - Brake Boost Vacuum System: Mechanical Failure
    P1479 - 008 - Implausible Signal
    C5 AR, B5.5 W8, and a suuuuuper slo mk4
    "If You Work for a Living, Then Why Do You Kill Yourself Working"
    2000 s4
    Fairfield, CT
    Re: Codes...
    a boost leak most likely will give you a hard time going into boost, check for a torn ttb.
    i heart my s4
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    Re: Codes...
    Quote Originally Posted by rms-s4 View Post
    Yeah I took it off to make sure I didn't miss anything, I even took the accordian hose off to make sure that was ok, I am thinking it's an o2 sensor, but I don't wanna have to replace all 4, it seems like that's what eveyone had to do in the past
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: Codes...
    Quote Originally Posted by B5in View Post
    some specs:
    2001 2.7T
    tiptronic
    your oxygen sensor is driver side, pre-cat. change it out.
    pressure test and check for boost leaks.
    B5 S4 AWE Stage 3 - sold
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Codes...
    check your black plastic hose that goes from brake booster to intake.
    I just tested mine and found it leaking when I did a pressure test. They are known to leak or break as they get older.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    Re: Codes...
    Quote Originally Posted by gointoscott View Post
    Do you know where to get a new hose besides the stealership?
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: Codes...
    www.genuineaudiparts.com
    I just ordered a crapload of stuff from there last week.
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    Re: Codes...
    What was wrong?
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    Re: Codes...
    Quote Originally Posted by Caddy7 View Post
    What was wrong?
    Still trying to figure it out, I am hoping when I get my Vast tip-chip it will fix the problem. It was suggested that the stock TCU isn't programed to handle the increased torq. so as a fail-safe it cuts power or thinks I am in too low of a gear & downshifts.
    I'll post an update when I get it situated for sure
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    Re: Codes...
    As far as the above codes basically there was a vac. leak in the hose connector on the brake booster & my front driver's side o2 sensor is on it's way out
