Results 1 to 18 of 18
    Established Member Two Rings Xenon01's Avatar
    Nov 30 2008
    Georgia
    Bad Diverter Valve
    So i was driving my s4 around today and i kept hearing a BOV noise. I checked my DV's and the passenger side DV doesnt hold the vacuum. Is it ok if i drive around for a few days with a bad DV?
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: Bad Diverter Valve
    its ok i guess just take it easy and stay out of boost. Get it fixed asap
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    I believe I had 2 bad DVs after chipping my car. Didnt take long to destroy the stock ones (oops). I just drove sensibly and did, in fact stay out of boost (sub 3k revs) and it was okay. I would agree, however, get them fixed asap. It doesnt take long, and it's something you could do in a quick night. (My install didnt go smoothly because they were kinda stuck onto the hose)
    Aug 06 2008
    Canadia
    if the other one works i wouldn't be worried. I just wouldn't drive like a mad man
    the B5 S4 is like the mafia... there is only one way out!
    Sep 20 2004
    2001 a4 quattro
    Sactown
    so how did you test the DV to see if it was working correctly or not?
    Aug 06 2008
    Canadia
    mine made a hissing noise when they failed and the engine was running.
    Nov 30 2008
    Georgia
    http://www.vaglinks.com/Docs/Misc/VA...rter_Valve.pdf Try this link. This is what i did. One of my diverter valves held the vacuum and the other didnt. I also noticed the bad DV was completely dry and was harder to take off than the good one.
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    it'll be fine to drive... just fix it as soon as you can... dont have to worry about taking it easy, nothing will break... just wont run to its full potential...
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Veteran Member Three Rings s4killer's Avatar
    Jul 27 2009
    audi s4 b5(sold( corolla 95 stick, jetta se, honda civic ex
    wisconsin
    [QUOTE=s42k5b;3176786]its ok i guess just take it easy and stay out of boost. Get it fixed asap[/QUOTE
    last year bought a apr r1 dv install and when the car accelerated very rare you hear a sound. (buuuuuuuuuuu or fuuuuuuuuuuuuu and disappeared)
    and I said to myself what's that sound
    two months after apr r1 dv remove and put the dv I had before and the sound is not never heard so
    that apr is not whether they are new but are bad at this point is kept. and continue with my stock dv
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    ouch...
    Jul 27 2009
    wisconsin
    ha?
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Jan 09 2008
    2001 S4
    NC
    Quote Originally Posted by s4killer View Post
    ha?
    Can you retype what you wrote earlier, it's a little difficult to understand. I'm not being a smart ass, I seriously cannot understand what you're saying, and I am interested, since I too have apr r1 diverter valves.
    Senior Member Two Rings SilverS4kg's Avatar
    Feb 04 2010
    02 Es Fo, 97 TAHOE
    978,MASS
    can anything even get damaged from getting into boost with a bad DV?
    02' S4 STGII "The Grocery Getter"// // // VEI / PODI // JHM // Borla // H&R // SSAC // OZ RACING
    VAST
    Jul 27 2009
    wisconsin
    Quote Originally Posted by laxman851 View Post
    sorry men i use translator becouse my english is very bad ok i try again in short version hjaha
    i buy the apr r1 is brand new install and i note the extrange sound i keep install for 3 months i i hape the sound fuuuuuuuuuuu uuuuu and disappeared this happen when i pull the car hard or semi hard so i put bakc my old dv stock and
    and these do not produce the same sound. oks no sound
    you think is normal?
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Jan 09 2008
    2001 S4
    NC
    Is there anyway you can get a video, the upload it on youtube and share the link with us?
    I would do what Xenon01 suggested and try this. If you pass this test, then your diverter valves are fine.
    Jul 27 2009
    wisconsin
    humm well my apr r1 after few months use, i keep in my closet for humm let me put back i try make a video but this take time
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Jul 27 2009
    wisconsin
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Veteran Member Three Rings Quikslvr's Avatar
    Nov 29 2006
    2001.5 Silver S4 6MT
    Utah
    Stage one minus
