Results 1 to 12 of 12
    Aug 05 2008
    Chicago
    Spacer and rim Qs
    Would 15mm in front and 20mm in back look good with these ( http://i3.iofferphoto.com/img/item/6...NRAEqKRGsn.jpg ) rims.
    Do I even need to get spacers for ADR 42s 19x8.5 et35 5x112 rims?
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Re: Spacer and rim Qs
    First, I dont think that rim fits the 2.7 if thats what you are looking for.
    Also, 15mm would be way to much. Most 35et you will not need spacer. If you do then 5 would probably be max.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Aug 05 2008
    Chicago
    Really, it doesn't fit? Damn, its a good deal too. 350 bucks for 4 rims and 3 with tires.
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    That is the ADR M Classic, correct?
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    Aug 05 2008
    Chicago
    Believe so. It says in the ad that their 42s but when I google m-classic usually comes up.
    I would think that the rims would fit since their 5x112. Did not know that there is more to fitment than jsut the bolt pattern.
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Well, what car are you trying to put them on and what calipers?
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    Aug 05 2008
    Chicago
    03 A6 2.7t. Stock calipers. These rims should fit, right?
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Unfortunately I still think they dont fit.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    Aug 05 2008
    Chicago
    Do you know why the rims wouldn't fit?
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    Isn't that the size most A6 guys sholud put on their cars? 5x112 et35 without spacers?
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Quote Originally Posted by blkrhyno View Post
    Yes but it also has to do with rim design.
    Want2play - If you want to get the ADR M Classics then do it. From what I know they do not fit but this is not from experiance, just research. If you get them and they work then let us know. As of now I dont see anyone replying to this thread that knows these rims in particular. Maybe you should call ADR or a distributor and ask them directly. Dont rely on us!
    I do however think the ADR M Sports will work.
    Good Luck, signing out!
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    Aug 05 2008
    Chicago
    Thanks a lot bro.
