Results 1 to 23 of 23
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    DIY mod for fog lights
    I'll update this after work if there is enough interest.
    Running Fog lights with factory switch whit the headlights off:
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    Re: DIY mod for fog lights
    I think there's already a DIY for this
    Edit: The write up is on AW http://www.audiworld.com/tech/ext11.shtml
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    If there is cool i wont do a write up, i just installed a wire from 15 power to #15 and #17 pin on the fog light control module ( big relay)
    Jul 15 2007
    2001.5 S4
    Utah
    Are those HID fogs?
    -Seth
    Jun 14 2007
    2000 S4
    Connecticut
    I recently did this, well a buddy did for me. he pulled out the fog light module from behind the glove compartment and soldered a few things and snipped a few pins. I think it's the best to have control of the foglights, and it looks sick.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    yes they are hid fogs
    Jul 15 2007
    2001.5 S4
    Utah
    Looks good. How difficult was the conversion?
    -Seth
    Jan 16 2008
    '15 S5, slippahs
    Home
    Yeah, any good write up on the HID fogs?
    May 06 2004
    W124s
    PA
    Quote Originally Posted by AudiTechS4 View Post
    I think this may be what I did? But instead of ign power I used parking light tap from the glovebox light. Both wires only draw like .1 A or something.. works
    Keep right pass left, it's the law!!
    Registered Member Two Rings i5wikcedi3's Avatar
    Oct 05 2008
    2001 Audi S4 Stage 2+
    San Diego
    Man, we need step by step instructions with pics please!!! That write up has no pics. Pretty sweet deal though.
    "Fear No EVO"
    GIAC Chip, AWE DP's w/ hiflow cats, AWE Twin 2 system, AWE DTS, AWE Boost Gauge, APR Bi pipe, EVO intake, 710N DV's, STaSIS T/S Suspension, Short Shifter, Euro headlights, RS4 clutch kit, 11 lb Fidanza flywheel, PowerStop D/S Rotors
    Oct 28 2008
    Virginia
    write up with pics would be appreciated. Any info on the HID fogs? thanks
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Yes I wanna do this! Thanks!
    Veteran Member Three Rings Go_S4's Avatar
    Mar 20 2007
    Nor Cal
    Never thought of doing this, a write up with pics would be nice...
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    I'll do the write up tomorrow morning
    its very easy.
    remove the glove box .
    there is a big relay behind it the relay number is 600(on the back of the relay)
    take relay out and look at the socket side.
    pin 15 and 17 (both yellow wires) clip from the back of the socket and give them a power source.
    I used ignition power,under driver side dash.
    1st post of the 5 for power.
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    so you just hook up both yellow wires to ign power source?
    Feb 09 2007
    00 S4
    MA
    there is a better way...I did it by the book and soldiered a wire to connect the 1,2,5 posts (IIRC) on the board inside the box, then clipped some pins off.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    why is opening the box and soldering any better? the 2 yellow wires going into the box are the signal wires from the headlight switch .Just give the ignition power and your all set
    May 23 2008
    Columbia, SC
    true...so you do just hook both yellow wires to the same power source?
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    Quote Originally Posted by Blake260 View Post
    that's the way i did it in both of my S4s. it's really easy but getting the box back in is a bitch
    '17 Ibis White B9 A4 quattro P+ S-Line
    Aug 20 2008
    Chicago
    Awesome, Thanks!!
    I was just thinking of doin this the other day..
    I also wanted to do a HID conversion but I was
    A. Worried that it would be too bright
    B. Don't know what color on the spectrum the factory HID bulbs are, I would want them to be the same..
    Feb 09 2007
    00 S4
    MA
    maddd bright....I get falshed quite often with 3000K fogs (pointed straight at the ground.)
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    And these fit directly on our S4s right?
    Where did buy them from?
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i rigged some tt hid headlight bulbs and balasts :) free hid for me
