Results 1 to 2 of 2
    Dec 19 2008
    NH
    High Pitch noise at 3200 RPM
    I have this high pitch noise that sounds like it is coming from the driver side front end. It isn't very loud, I have to shut the radio off and listen to hear it. Only happens on the highway when in 5th gear around 3200-3400 RPM (around 75 mph) and only when I put a constant pressure on the pedal, if I accelerate the noise goes away. I read postings about the dental drill noise and the turbo failing (watched some videos on youtube) but my noise isn't nearly as noticeable and sounds different from the ones I saw. The best way to describe the noise is if you hit a tuning fork or a pinging noise. Does anybody have any ideas what it might be? It is a 2003 A4 1.8T Quattro
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Re: High Pitch noise at 3200 RPM
    http://www.audizine.com/forum/showthread.php?t=250767
    Check my thread out, hope that helps.
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
