Results 1 to 19 of 19
    May 06 2008
    minnesota
    Oil leaking!! Pictures in side!! help please!!
    Ok my car is leaking oil underneath the engine rite at the oil filter. i dont know where its coming from but its leaking. I have pictures that you guy can look at. Anybody know of anything??
    You can see where it drips from.
    started my car this morning (its been 1 week) for about 10 minutes and this puddle is there. but it always leaks like this when parked. dont know if it still does while driveing.
    Feb 02 2008
    17 pure white vr6 Touareg sport tech
    Re: Oil leaking!! Pictures in side!! help please!!
    Looks like your oil cooler, but I cant say for sure, somebody more knowledgeable will chime in soon i'm sure. If I remember correctly though, once you pull the filter, its just two hex bolts and a gasket. The gasket is what you need to replace.
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    Quote Originally Posted by destrolock View Post
    I'd agree, however I would also suggest a different filter during your next oil change.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    May 06 2008
    minnesota
    so it could be the oil gasket??? hard to replace??????
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    oil cooler probably.. does the leak go up any higher or is that the highest point and where the oil starts?
    May 06 2008
    minnesota
    Quote Originally Posted by njm23 View Post
    Thats about how much it leaks from time to time.
    May 06 2008
    minnesota
    how does this gasket look like??
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    If there is nothing coming down from above I would guess oil cooler or the lines connecting to the cooler. Looks like it's been doing that for a while and since everything behind it is covered in oil I'd say it does leak while driving.
    That's a lot of oil to loose so I'd get it fixed asap and make sure that the oil level stays high enough to get to a shop.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    I would suggest spraying engine cleaner all over the area with oil.That way you can tell exactly where the oil is coming from.
    Nov 30 2008
    06 Wrx
    Olympia, WA
    I know this thread is old, so i hope i don't get to much crap. but i didn't want to start a new one, and this guy has pictures. :) But did you ever get this fixed? Just had mine do this too. Its been a slow leak getting worse. Not cool.
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Quote Originally Posted by stevejones19 View Post
    like its been mentioned its probably the oil cooler, they tend to go bad
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Nov 30 2008
    06 Wrx
    Olympia, WA
    ok. thanks
    Registered Member Two Rings
    Apr 15 2009
    Michigan
    what if the oil is coming from above the oil cooler but still right in the general area, what might then be leaking
    May 28 2009
    saint paul mn
    Wow, that's an easy one.
    There is a big o-ring between the oil cooler and the stand. It's like $10.
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    ^^^X2 on the oil cooler gasket !-ecstuning has them for about $3
    when i replaced mine a couple months ago, the nut holding the oil cooler in place was hand loose!!
    Aug 13 2008
    Indiana
    Your obvious dripping leak appears to be the oil cooler. But there is oil coming from other places too. Check your valve cover gaskets. It's also extremely likely your leaking from you cam chain tensioner gaskets. Gaskets are cheap but the labor is quite extreme. If your timing belt is near due or hasn't been done though its a great time to get it all done. All of your front seals: Crank, cam and cam chain tensioner seals as well as valve cover gaskets at the same time. You will save hundreds in labor but if you have it done it will still be over 1k to fix all that.
    -Nic
    Apr 15 2009
    Michigan
    i replaced the oil cooler o-ring a few months ago. Could the upper oil pan gasket be leaking. i've been looking for threads but havnt seen anyi=one having a problem with the upper gasket leaking
    Veteran Member Three Rings stack's Avatar
    Oct 27 2008
    E46 M3
    Queens NY
    i have got the same thing.
    but somehow it was the turbo that was leaking
    Senior Member Two Rings Rau's Avatar
    Dec 19 2007
    2001 Audi A4 1.8T Quattro
    San Mateo CA
    Quote Originally Posted by stack View Post
    same here. my turbo oil feed/return lines are leaking right at the turbo
    Anybody know where my lightsaber is? It's purple, and it says " Bad Mother****er " on it.......
