Results 1 to 19 of 19
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    Stock headlight question( indicator bulbs)
    is there a way to turn off the indicator bulb when it is just lit up but turn on when you hit the turn signal ?
    lights are on but no side bulbs lit up
    when you hit the turn signal left or right they flash
    is that possible?
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Stock headlight question( indicator bulbs)
    no
    Sep 27 2006
    no wire to cut or anything of that sort? lol
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    It's really easy.
    The bulb is Dual filament, there will be 4 wires. 2 on each "side" of the wedge.
    Take both inner most wires (one on each side of the wedge) and pry it off. There you go.
    Remove both wires in red:
    Easiest to take a flat head screw driver and pry it off.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Registered Member Two Rings
    Nov 27 2008
    2001.5 Imola s4
    VA, MD
    So Are You Saying That When You Turn On Your Headlights Your Parking Lights Dont Come On?
    2001.5 S4
    Darintake Mod, 18" Unknowns, Nitto 225x40, Dual Forge 007 DV's
    Veteran Member Three Rings RAyala2.7T's Avatar
    Mar 08 2005
    Austin, TX
    I took a single filament bulb(3056, IIRC) and shaved the tabs on the side down enough for it to slide in and out easily yet be snug. A lot easier than cutting wires and completely reversible.
    Rob - 2000 Audi S4 VAST Stage III
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by devildog6 View Post
    Correct, corner lights never come on. With lights on or off; but blink normally with turn signal.
    Quote Originally Posted by RAyala2.7T View Post
    How is taking a flathead screwdriver and bending off a wire (which mind you is weaker and thinner then a piece of solder) hard? I have done both, where I bought a single filament wedge and had to shave the sides (when I ran LED turn signals), and that takes a couple minutes of shaving, testing seating, etc.
    If it takes you more then an actual second to break off the inner wires, then you probably shouldn't be working on your own car.
    Mar 08 2005
    Austin, TX
    Quote Originally Posted by Rated S View Post
    I was referring to the wire cutting option, as stated in my previous post. Don't resort to childish banter please. Thank you.
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Okay, I guess we can play this game:
    1) You didn't state any specifics; your post came after mine, where I used the term 'wire' to describe the piece of metal that makes the light work.
    2) No one mentioned a process on which wires to actually cut which led me to believe you were talking about "my" method.
    3) I can argue, to my death, that I was making a statement about how one should not work on their own car if they cannot remove a wire from a light wedge, not going into any specifics with anyone.
    Mar 08 2005
    Austin, TX
    So we can squash this, I wasn't referring to your post. I was commenting on my experience with how I performed this simple mod. Can we move on please?
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    I just cut the wire.
    Sep 27 2006
    It's really easy.
    i think im going to try this .. so its identical on each side? and just cut the 2 inner most wires?
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Sep 27 2006
    do u have a picture with your lights on like that?
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by Bigair View Post
    They look identical on each side, where you will see 2 wires on each.
    Cut the inner most wire (closest to center of bulb), then turn it around and cut the "same" wire positioned on the other side.
    And here's a not so good pic:
    Sep 27 2006
    alright cool ...you have 6k hid's and fogs?
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Yessir.
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    hey, any advice for setting up HID fogs? I have a 3k kit that's been sitting around for months and one of my fogs just went out so figure this is a good time to do it
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Quote Originally Posted by JD797 View Post
    Get ready to improvise a way to get the bulb to be held in to the fog housing. I used these pins:
    Which I got @ work. And dremeled in to the housing and bent them around the bulb. It's hard to explain, and I would take a picture, but my bodyshop spray painted my grills closed, so now I can't access them.
    Apr 10 2008
    lol its cool, i appreciate the effort, im sure ill figure something out
