Results 1 to 33 of 33
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    GIAC X finally installed w/ 710n and tested! UPDATE!
    i was finally able to put the 710n on today and the car woke up from deep sleep! Giac is crazy agressive through all the gears, such a drastic improvement over stock. I didnt run it that much but i did a few highway runs and 0-60s and i was impressed. This was my first time flashing a car and this is my second b5. I highly recommend a giac-x for those with a '00-01 1.8tqm. I also want to thank a member "Enclave" for hooking it up with such a great deal, $185 shipped!!!! For now, my a4 is just right as far as power goes, but i will open it up more with a catback turbo exhaust sometime this spring. Until then, i will continue with the exterior/interior mods! GIAC-X
    2018 Mercedes GLC 300
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Re: GIAC X question
    Maybe not violently, but I thought it was normal for it to kinda shudder on the first startup, and then you let it idle without giving it any throttle so it can adapt?
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    May 19 2007
    Bay Area
    Re: GIAC X question
    I'm bored today man lol. It did this when I replaced my MAF, and I was told to let it sit and idle for a few minutes and DO NOT touch the gas pedal during this few minutes. Once it all kind of smooths out (it shouldn't be bucking and shuddering anymore) you should be fine to drive it.
    SIXFIVEOHphoto
    Dec 05 2007
    Re: GIAC X question
    I would say it is your plugs. Did you change the gap on them upon installation of the new ECU? Maybe you need to find a suitable gapping as there are people whom do not like the .028" gap. Some people gap at .030" and so forth on a flashed ECU. I use Bosch F6DTC (pregapped) and have no issues.
    When I got my ECU flashed, I placed my plugs and dv in before getting flashed. And I do not recall any shudder after install. We even took it around the block to see how much boost I would run no more than 2 min after flashing it
    May 19 2007
    Bay Area
    Re: GIAC X question
    But would the gapping on the plugs make a difference if the ECU is chipped when it's just at idle? I thought that would only make a noticeable difference during boost...
    SIXFIVEOHphoto
    Dec 05 2007
    Re: GIAC X question
    Handheld switch via OBD II port (slopoke has one for sale in his sig). But plugs can grant any car a bad idle. On throttle is a different scenerio.
    Dec 05 2007
    Re: GIAC X question
    You will be ok for a day on your stock dv. Just don't do too many WOT runs trying to hit that 22psi spike. And I suggest the Bosch F6DTC plugs. I mainly run them because Mike Hood runs them. Then I learned of how many others do also. They are good for stock and BAT applications. Plus they can run for ~25k before needing change.
    But new plugs and a dv is a must upgrade.
    San Jose, CA
    Re: GIAC X more questions!!!!
    do you still have your vag? look to see if you have any codes.
    also you can download the giac flash loader on your pc and switch in between programs.
    http://www.giacusa.com/flashloader_handheld.php
    Veteran Member Two Rings
    Mar 15 2004
    Re: GIAC X question
    It might be on the stock program. I've havnt run that ECU for a whole year because I've been on a standalone.
    2001.5 A4 1.8tqms
    Pectel SQ6 ECU
    2.0 built motor w/ AEB head
    GT3071r w/ Full-Race Manifold
    725cc Injector Dynamics
    Startup Racing Contest Suspension 600/700
    Dec 05 2007
    Get a boost gauge .
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    Get a boost gauge .
    X2
    Very important to have when you chip your car.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    yea get a boost guage. whether a cheap autozone one or a nice one.
    TEAM|AXION
    Dec 05 2007
    Quote Originally Posted by Ado View Post
    From the link
    Click here to download Flashloader Switcher
    for use with 97-99.5 Audi A4 models
    with new GIAC Software
    That's some bull. I think it may still work though. Maybe!
    Dec 05 2007
    Uninstall it from your hard drive . Maybe you can call up GIAC and inquire if it will work for the AWM ECU. Or if there is a program that they have for free that does.
    Mar 15 2004
    That link http://www.giacusa.com/flashloader_handheld.php works with it. Just install it, plug it into the OBDII port, hit Read, should allow you to choose either Stock or Pump. The mode it is in will be highlighted green. Make sure you hit read again to check that the change went through.
    Also while your at it, clear the any codes that might be on it.
    2001.5 A4 1.8tqms
    Pectel SQ6 ECU
    Los Angeles, CA
    Re: GIAC X finally installed w/ 710n and tested!
    Bump, guys i recycled this thread because it is the same topic now FIXED!
    Mar 07 2008
    93 Saab 900, XR650R,
    Re: GIAC X finally installed w/ 710n and tested! UPDATE!
    got chipped like 5 weeks ago and having a very annoying problem now. it misses like a bitch every time i when i get i it. but once i fight though it, it stops??? i don't get it i have a colder plugs and run 93 Sunoco (best gas i can find that's not 106/116)
    anyone else ever have this problem??
    Established Member Two Rings Kaytek's Avatar
    Nov 19 2005
    Ottawa, Canada
    Could be dying coilpacks. Had a similar issue where it missed while mashing the gas in 4th gear at low rpm. I swapped the last 2 old coilpacks and everything is fine now.
    2001 1.8TQ Tip - GIAC X - Startup Racing Vogtland GTs
    Mar 07 2008
    alright ill check that out thanks it seems to happen when boost comes in in all gears
    i was thinking of maybe going 4.0bar FPR and changing the fuel filter also??
    Oct 25 2006
    oregon
    Quote Originally Posted by thopp00 View Post
    I wouldn't fight through a misfire.
    Is your CEL flashing when it happens? Plugs gapped correctly? If one is off gapped, it can screw up your coil pack.
    As for 4.0 FPR no reason to do it-the flash is designed to run on a 3 bar.
    Can't hurt to change your fuel filter, etc. Always good to keep up to date on these parts.
    Mar 07 2008
    Quote Originally Posted by Oricle View Post
    No CEL What so ever Never Flashes or anything, as for plug the gaps are all correct it ran fine on the hotter plugs?? which i don't get
    Its weird how it runs fine after like 15 mins of driving? then goes away? idk its just annoying and yes i let it warm up and everything.
    Los Angeles, CA
    hey thanks for using my thread!
    Dec 05 2007
    Getting a boost gauge?
    Los Angeles, CA
    Me? Yeah.
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    To tell the truth, I can't wait till my A4 gets chipped. Even though I have my S4, I think I am going to enjoy a chipped 1.8t.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    mines getting chipped on Thursday. Thats all im looking forward to right now.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Senior Member Two Rings Stumanbmx's Avatar
    Nov 04 2007
    '00 A4 1.8TQM
    Minnesota
    I got mine chipped about a month ago. It was fun for about a day...
    Mar 07 2008
    I love my car its great on gas and it faster then the average car.
    i think my problem i detention i had it for a while before whe i would get 91 then put in 93 and it went away but now it back?
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Then the average 1997 1.6liter honda civic bubble hatch...
    Nov 02 2008
    Boulder & Seattle
    So my GIAC ecu came in a two days earlier than i was expecting (was scheduled for Friday 1/2/09) to be dropped at my house, but I came home to find this small little box and was like O.O haha
    have the GIAC + Bosch 710n and OMG. Its godly better than earlier, though i JUST got full boost for the first time yesterday since buying the car (swapped the K03 for a K03s and found the wastegate linkage had snapped on the K03, so i was getting no boost) but GIAC + K03s is amazing.
    NorCal1.8T how was yours?
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Dec 05 2007
    I remember a thread before on the k03 vs k03s. Even though the fins on the turbine wheels is different, I read that the reason the k03s has 20 more hp over the k03 was due to slightly bigger injectors (in other words, the AEB w/k03 uses different injectors than the ATW and AWM w/k03s). Might want to look into it as it may grant you a couple more ponies, but do more searching as you don't want to mess up your A/F (don't know how the tune would run with different injectors).
    Second opinion on this matter for confirmation would be appreciated, for clarity. Thanks!
    Los Angeles, CA
    Quote Originally Posted by geeky View Post
    I agree, ko3s and giac-x help a lot. Its like a different car now, the 1.8t should have been given more turbo boost coming out of the factory originally. I'm not sure how much I'm boosting since I dont have a gauge yet, what do you spike at? Also you should look into the ko3 v ko3s swap like said above, you might not be running to full potential of the ko3s.
    Nov 02 2008
    Boulder & Seattle
    I swapped the k03 for the k03s as when I did my front mount I found a crap load of oil and the turbo was bad. A lot of shaft play so a friend of mine swapped to a k04 and had his k03s lying around. Got it for 100 with 65k miles on it. Took it to the stealership and everything was fine on the turbo and so I ended up with a k03s haha
    Edit: as for my peak, no idea. I have a vdo gauge ready to be installed but waiting for the new fitting + line t measure the boost
    and i filled the tank up on Premium today (after filling up, noticed that its 92 octane) now would the difference of 1 octane cause the car to shake while in full boost a little bit? (sorry to thread jack, NorCal)
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
