Results 1 to 6 of 6
Thread: Need Help
    Established Member Two Rings 02QuattroA4's Avatar
    Sep 29 2008
    2002 Audi A4 1.8T Quattro
    Southern California
    Need Help
    I need to know if i would be able to put normal coolant in my 2002 audi A4 quattro. it had 85k miles. and on my screen it has the warning saying that my dynamic headlight dimmer control not functioning. should i take it to the dealership or is there a way to fix the lights myself.
    Sep 29 2008
    Southern California
    Re: Need Help
    bump
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Re: Need Help
    What are you asking? First you're talking about coolant then you go to a dipped headlight..
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Sep 29 2008
    Southern California
    Re: Need Help
    well i have 2 separate questions. i wanted to know if i could put normal coolant in my car, or if i had to buy coolant from the audi dealership.
    second, i wanted to know if there was a way of fixing the warning on my car. the dynamic headlight dimmer control not functioning. what does it mean.
    Jan 24 2007
    Re: Need Help
    no you should def. not put normal coolant in, just go to dealer buy yourself g12 or g12+.
    Do you have a fault code for headlight? post it & i'll check for ya or you could search
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Re: Need Help
    NO. you can't put normal coolant in...napa sell pentosin G12 which you can use and the dealership sell the same stuff but napa is cheaper. as for the headlight im not sure..have you tried turning your can on and off..i have gotten a headlight warning and i just shut it off and it went away..must have been a fluke thing
