Results 1 to 11 of 11
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    Transferring a reflash
    If you friend has a car with a flash on it , would it be possible to use limmiwinks to read everything u need then apply the same settings to a non flashed car ?
    Mar 27 2005
    The Cold North
    Re: Transferring a reflash
    if you both have the same ecu code you may be able to swap ecu's and have a shop re-set the immobilizer. But unfortunatly you can't just read the info and transfer it to a new ecu using lemmi's.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Quote Originally Posted by 03 silverbullet View Post
    Sure...
    But it will cost you $500...
    APR Tuned Serbia
    Authorized APR Distributor
    Dec 05 2008
    im just now reading what lemmiwinks is for , i didnt know if it was similar to a program called Open ECU or not. with that program u can scan a friends car apply it to yours and tweak as needed. Open ECU is being used by EVo and STI right now i dont know if it will work on the Audi
    Mar 27 2005
    The Cold North
    your going to have to break down and buy a flash from one of the major companies. APR, GIAC, REvo, etc...
    2020 Chevy AEV ZR2
    Dec 05 2008
    i have another post on here about a GIAC 1.5 chip , its possible my car already has this in it i have not taken the ECU out yet. The car has been getting horrible gas mileage and is completely stock. I was trying to figure out what i could use to tweak this because in the lower RPM in second the dash tells me im getting 9 mpg ... in second on a flat road under 2k rpm
    so i am wanting to see whats going on i think its dumping a bunch of fuel and running rich under 3k rpm
    I just got my cable and now im trying to learn the limmiwinks software, i was just wondering if it would be easier to scan my friends car put that on there and then tweak it
    just found this
    http://homepage.mac.com/edyjun1/S4/l...ng%20Notes.htm
    Mar 27 2005
    The Cold North
    logging the actual vs requested boost will give you an indication if you have a chip or not. log block 115. logging block 020 will give us some ideas of what the timing looks like too.
    You may want to figure out the underlying problem before just adding/subtracting fuel or timing.
    2020 Chevy AEV ZR2
    Dec 05 2008
    ok i will set it up to run those on my way home
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    just found this
    Sadly you cant just copy and paste flash software as the tuners embed values in the tune that are specific to your car VIN and immobilizer.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    sounds like you are trying to copy software.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Dec 05 2008
    copy software ? there is no software to copy. just take the settings out of one ecu and load them into another
