Quick question - how is the engine idle when you first start the car controlled? Normally when I start the car cold the rpm's jump up to 1200 and sit there for a minute or two before dropping down. As it has gotten colder in this area I have had intermittent starting issues (cranking over and catching, then dying out but starting the next time) and now I have noticed that in sub-freezing weather that about 1/2 the time the rpm's don't go up to 1200 even when the car is first started.
Is that normal, and what normally determines that?
