Results 1 to 14 of 14
    Oct 01 2008
    Philly
    Cracked my oil pan
    Cracked the oil pan on the A4 today..kinda sucks. Just wondering if how many of you guys have replaced the pan and how you went about finding a new one stealership, yard, etc. Just trying to find the cheapest option.
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Senior Member Two Rings Wyo_A4's Avatar
    Oct 17 2008
    Laramie, WY
    Re: Cracked my oil pan
    My cars been through two of them while i've owned it. I got them both from a family friend that runs a european repair shop for the price he gets them for.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by Wyo_A4 View Post
    cool. are you just bragging? because that helps nothing unless you are offering it to the OP
    anyways.
    here you go man
    http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    had the same thing happen to me real early when I got my car like a month after I got the car in fact, I got a new oil pan from EBAY for like $80 and it turned out it was for a B6 not a B5 well I couldnt return it because it was a 7 day money back warranty I was a day late. Well then I found out that I had to do a lot of work to get it out so in my rush to get driving again I drained the oil and JB welded the crack, yeah I know it was dumb but it held for a few months no problems then it started dripping a little a small drip so I just got it replaced. but you know I am sure it would have held with a little maintenance and some new JB weld. Bottom line just JB weld it if it's not too bad like a hair line crack like I had otherwise just get one on EBAY or ask AP specialists they should have one, and they cant be more then $80.
    You don't want me smiling at your cameras...
    Alex 'BasicCable'
    GCC Robot.
    http://steamcommunity.com/groups/Audizine
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    ^^^don't listen to this guy
    get a used oil pan and change it. unless you want your jb weld to come off on the road, loose all oil pressure, and destroy your motor.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    May 18 2008
    SOOOOOO Cal
    HAHAH I knew that was going to happen, I changed it eventually. But yeah dont do what I did just replace it.
    Alex 'BasicCable'
    GCC Robot.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    I'm in the Philly area, I have a spare pan for a 2001 1.8T NIB if you want it. I'll check my receipts to see what I paid, it was slightly north or 80.00 though. I have it now you van pick it up on Sunday or swing by ASP where I will be all day 12/20/2008 and grab it. Another option which would involve waiting would be used from car-parts.com
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Oh man where were you guys with those eBay links when I cracked mine? I bought one off MJM for $125. It was a huge PITA to swap them, you have to drop the subframe and raise the motor by loosening the mounts, not a fun task when you're working on the street outside your house.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by boostedup View Post
    jb weld is perfectly fine for small cracks. you're hardly going to loose all your oil and oil pressure through a hairline crack.
    jb weld is quick and simple to use. much easier and cheaper than replacing the pan all for one crack.
    just regularly check the oil level and status of the weld and you will be good to go until you get it fixed later on
    Current:
    Previous:
    Sep 01 2005
    Quote Originally Posted by sean1.8t View Post
    i hear what your saying, OR you can just fix it right, and not worry about your oil levels. that's all i was saying.
    May 18 2008
    SOOOOOO Cal
    Well all I had was a hair line crack, that was dripping a bit so after a few days without moving the car I would get a small spot on the floor I was not sure why so I checked lines for hours until I noticed that the oil was coming out of the oil pan it self I had to lay there for like 30min until I saw a drip fall, so I looked online for an oil pan blablabla wrong one JB weld it bam fixed for over 6 months until I got it fixed and not because of any problems just thought I should fix it.
    Alex 'BasicCable'
    GCC Robot.
    Sep 17 2006
    SLC, UT
    well you should be regularly checking fluid levels in your car anyways. so it's not like it's extra work. and it's not hard or time consuming at all. takes less than 1 minute to do.
    all im saying is you are just wasting time and money at that point. if there is a simpler and cheaper way to achieve the same results, then why not take it.....
    Current:
    Previous:
    Oct 01 2008
    Philly
    Quote Originally Posted by bassed View Post
    Awsome Ian. I'll be grabbing it from you then. I was going to PM you anyway when this happened since i figured you'd probably have a spare.
    Thanks for the input though as well guys.
