Results 1 to 8 of 8
    Senior Member Three Rings Sunny4's Avatar
    Aug 01 2008
    Mt. Prospect, IL....CHICAGO
    Burning smell thru the air vents
    Anyone have a almost something liquid burning smell come out of their vents occasionally? When im driving with the auto temp at 70 deg, and the re-circulate button off I get this weird smell that creaps in. For a while i thought it was outside exhaust from other cars but then the same smell keeps appearing. It goes away when i put the re-circulate button on and im fine but then the windows fog up. Kinda a paint, checked under the hood and nothing seems to be leaking. Anyone have this issue? Be it oil, trans fluid, etc...
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Re: Burning smell thru the air vents
    Quote Originally Posted by Sunny4 View Post
    Valve cover gaskets. Common. Cheap fix.
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    cheap fix meaning replace valve cover gaskets?
    Aug 01 2008
    How do you explain the intermittent smell. And how easy is this fix?
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    I had the same thing it would come and go, shop just told me i had leaking valve cover gaskets. I got excited when i didnt smell it for awhile....then my Minimum Oil level light came on...
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Aug 01 2008
    HOLY S**T, I turned on the car yesterday and brought my trusty flashlight to check under the hood and what do you know, there is smoke rising from the front left side of the engine. So there is definitely a leak as it is the same smell coming from the vents. I thing someone hit it on the valve cover gasket point. Taking it to the dealership on 15th to get it taken care of with the blown seat heater.
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    cars are know to have a small leak after awhile.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Same issue... also with blown passenger seat heater... :(
    Just spent 2 weeks at dealership..... ugh
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
