Vinny and I went to Speed Industry tonight and dyoned our cars on their Mustang Dyno. 4 pulls each. Neither one of us made the power we expected - the guy at Speed Industry said he has taken cars off his dyno and brought them to the Mustang Dyno that was at Wheel to Wheel and found that his dyno typically reads in 10% low. Who knows if that is true or not, all we have are the plots..
First plot: Torques and HP of our two best runs. I wish he would have rev'd the APR plot out a bit further as it almost looks like there is more power in the top end.
Second plot: Same two runs with AFR and Boost - the GTRS kit was boosting much higher than my APR kit
Third plot: Neither one of us had any real opportunity to sit around and tweak our sytems. My APR is very limited in what I can do, and Vinny literally got is SPS today so had no chance to fine tune anything. I did however, log my plots. On my last run I turned up the timing 5.5 degrees. The log still showed almost all 0 CF's. Either way, this is the plot of the baseline software and then turning up the timing 5.5 with lemmi.
for those that are interested... here is my log after bumping timing 5.5 degrees. This is the best run I had with the APR kit. Google Docs is not working from my job. I'm not sure what the lambda oscillations are all about. It looks like I could turn up the boost and still be pretty good since i start running a bit on the rich side.
http://www.a4mods.com/pics/random/dy...ull4_5pt25.csv
Dyno - significant gain with this small tweak - 12AWHP, 11 Ft-lbs
I think all in all this is a good baseline. I think both vinny and I are a bit disappointing in our numbers, but it is what it is. The goal was to get another GTRS manual down there for an even broader spectrum.
oh and also, I bought this APR kit a while ago - it is the one that DJL5S (spelling?) dyno'd at about 310 whp on fwd if I recall correctly
