hello, I'm building a 1.8t engine and i'm installing the main bearings for the crank shaft, in the package I have 6 bearing with a slot for the oil and 4 that are smooth and 4 thrust bearings. ok i'll do my best to explain my dellima, the machine shop took my bearing so i have no referance how the bearing go on the caps. the block gets 5 bearings with the oil grooves self explanitory, the caps gets 4 smooth bearings. where does the other bearing go that has the oil groove? does it go on the number 3 cap that has the thrust bearings or do I have 1 too many bearings with the groove and it should be smooth?
