Results 1 to 22 of 22
    Senior Member Three Rings staubach333's Avatar
    Feb 21 2006
    no headlights...please help!
    i turned on my headlights before and i have no low or high beams...every other light works fine...the only thing that works is when you pull on the blinker to flash your high beams, they will flash...that is how i drove the car 5 miles home, holding the high beam lever the entire time...sorry to all the people i blinded lol...whats going on here?
    Past---1998.5 A4 2.8Q---18" Privat Netz Wheels---H&R Sports/Bilsteins---DEPO ECE Headlights w/ DDM 55W HIDs---
    Present---2005 S4---18" Alzor Style 050 Wheels---XS Power Catless Downpipes---AWE Track Edition Exhaust (x-pipe, non-resonated)
    AKA: Stub
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: no headlights...please help!
    theres a short in your headlight switch, it causes the plastic piece, holding the brass piece that completes the circuit, to melt around it and hold it from completing the connection.....
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    check your headlight fuses and bulbs. If you headlights blew and shorted the system out, your fuses should have popped.
    Those are the two things i would check first.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by geeky View Post
    i've had the same problem, word for word of what he said. and its common in the pre-facelift a4's....
    Nov 02 2008
    Boulder & Seattle
    Its a common thing i see at school/at work.
    Many people don't understand that when a headlight bulb goes out, they need to change it asap, because if the filament somehow bridges together or moisture gets into the bulb itself, it can short the system out and when that happens, the fuses should blow and if they don't, you're going to have a massive headache with wiring, relays, switches, etc. for the headlight system.
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Feb 21 2006
    all the bulbs are 2 months old they are fine...and the first thing i did was check the fuses, none of them popped
    AKA: Stub
    Senior Member Three Rings a4mafia's Avatar
    Aug 22 2008
    B5 A4 Avant. Ford F250 PSD. Mazda3. Raptor 700r.
    Cincinnati
    Quote Originally Posted by a4mafia(Red) View Post
    trust him! we've done this a thousand times!
    Nov 30 2008
    06 Wrx
    Olympia, WA
    Go to the DIY. i just repaired mine from it. but something else went out, so i just got a whole new headlight switch. And there is a ton of threads with this same problem. So searching is your best friend.
    Feb 21 2006
    do you think i could hit it with some of that electric contact cleaner without taking it apart? just to see if that will work?
    AKA: Stub
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by Stub333 View Post
    no i dont think that would work....but you'd have to take it apart just to spray the cleaner on there right?
    Feb 21 2006
    someone had said to me that you can spray it in there somehow without taking it apart idk that sounds a little shaky...i think im just going to order the whole assembly new and install it does anybody know the exact torx bit sizes that i will need
    AKA: Stub
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    I believe that you need something like a T25 to get the airbag off of the wheel and then a T55 to get the wheel off itself. Then, you can get the other bolts that attach the switch with the small torx as well.
    You can also get the working assemblies from A-P Specialties who is a vendor here. I paid 35$ for mine and it has been working perfectly.
    Hope that helps
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Established Member Two Rings Ghostrider's Avatar
    Jan 31 2007
    86 Alfa GTV6, 91 Toyota HDJ80 Land Cruiser, 2005 Miata, 2020 Miata, and Lexus GX 460
    Charlotte, NC
    Had the same problem after a 14 hour drive, with about 10 minutes to go to my destination. It is the switch, bar none.
    Veteran Member Three Rings GetAudiHere's Avatar
    Mar 06 2006
    Minnesota
    I dont mean to thread jack but instead of making a whole new thread.
    Ok so i went out to my car started it up and immediately turned on the headlights. When i turned them on only one went on...so i turned them off and back on again and then the other one went out....both were out now. The amber bulbs still work, havent tried high beams but what do you guys think this could be?
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by erikas3 View Post
    Hope that helps
    i dont use a t55....i use a big hex key....its not the exact fitment, but it works...and save some money, i think its a t25 and a t10 for the other torx you will need.
    Jan 31 2007
    Charlotte, NC
    Quote Originally Posted by GetAudiHere View Post
    Simple, when one headlight bulb goes out the other is soon to follow. Hence the reason for replacing them in pairs.
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by Ghostrider View Post
    what would be the reason for that?
    not to be contradicting you but i drove around with a headlight out for awhile, i cant even tell you a time bc it was out when i bought the car, but i never notice bc i had the fog lights on all the time(my fog lights are set inside the housing of the headlight) so it always looked like they were good.
    Jan 31 2007
    Charlotte, NC
    It just happens. The only hypothesis I can make is, that there was a surge in the electrical, since only one light was working, thus blowing the other one. I agree with what you are saying about not noticing, since I have my fogs inside the housing as well.
    Mar 06 2006
    Minnesota
    how long do headlight bulbs typically last? Ive only had mine for a little under 2 years...
    Jan 31 2007
    Charlotte, NC
    It all depends, it's like a light bulb that you have in a lamp. The longer you keep it on, it will not burn out. Think of it this way, if you fire up the lights, voltage goes through the filament that is at a higher rate. If you keep them on, its constant. A little under two years is a decent amount. I had mine a little under two and they needed replacement, ironically this occurred after I replaced the light switch.
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    You can also get the working assemblies from AP-Specialties who is a vendor here. I paid 35$ for mine and it has been working perfectly.
    Hope that helps
    We have the switch for you if you want it...$35 + shipping...We have over 1000 Used Audi parts, with a focus on B5 A4 parts!!!
    Let us know if we can help!
    Chase
    Team A&P
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
