    Nov 15 2008
    La Crescenta, CA
    D3 Installed, a couple problems :(
    ok guys, i just installed the avic d3 but i have some problems. My rear speakers & factory subwoofer doesnt work. I tried everything and couldnt get those two to connect. I couldnt find which wire to tap into. Also, how does this unit even turn off? I know that you can turn it off from the menu but is there any other way? Also, the Menu, Map, Track buttons on the left of the unit are always lit up? How do i wire this so it will turn off with my lights. Please help! Thanks.
    Also, did you need a special adapter or did you guys just tap into stock wires. I am using the Power Harness behind the d3 for speakers? I dont need the a/v harness for sound do i? I am not running an aftermarket stereo system.
    08 A4 S-Line 2.0T - H&R Springs, 20% Tint, 6000k HIDS, 3000k Fogs, 19" Axis Penta's, H&R Spacers, Blacked out Grille, NE Prototype Intake, APR 91 oct.
    Nov 21 2008
    2009 A3 2.0 quattro
    Re: D3 Installed, a couple problems :(
    If the unit doesn't turn off with the car, you've tapped its primary power line (usually red, IGN) into the memory line (orange or yellow) on the car.
    Nov 15 2008
    La Crescenta, CA
    Also, my rear speakers & factory subwoofer dont work. I couldnt figure out where to power them up from. I tried everything. I wish i could find a DIY for this.
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    did you buy a radio adapter harness? all you have to do is match the color wires and youre good to go! you can also buy them at best buy, circuit city, crutchfield... pretty much anywhere that sells car audio stuff.
    http://cgi.ebay.com/ws/eBayISAPI.dll...12&refid=store
    ~~ engineered in germany... modified in brooklyn ~~
    Nov 15 2008
    La Crescenta, CA
    It already includes the harness...I tapped into the harness
