Results 1 to 9 of 9
Thread: Fogs with DRL's
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Fogs with DRL's
    so right now i have it vag'd to Canadian mode, but i don't like that i cant shut off my lights completely
    If i do this CLICK will i still be able to run fogs and ambers when i want, and be able to shut off all my lights.
    I believe i will have to re-vag to Rest of World also, which should also let me use high-beams and fogs on top of what i have now!
    just wondering if anyone has any one done this
    Please Drive Right
    Jun 02 2008
    Re: Fogs with DRL's
    bump
    no one has done this
    guess ill be the guinea pig
    Please Drive Right
    Aug 26 2005
    Re: Fogs with DRL's
    The various codings, provide different lighting function as you figured. The "Rest of World" coding works just like the US coding does, with stock wiring.** The situation is that US/CDN spec A4s are wired such that the fog light switch is powered from the low beam headlight circuit. Connected this way, the fogs light switch is not energized if the low beams are OFF. That is why the fogs only turn ON with the low beams ON also.
    For Non US/CDN spec cars, the fog light switch is powered from the Load Reduction Relay, J59, terminal 2, and that provides +vbatt to the fog light switch whenever the ignition key is ON. Therefore with this wiring allows the fogs to be ON without the low beams ON also, but the parking lights will be ON too.
    The coding for the "Northern Countries", is different. In that mode, the all of the lights are ON with the headlight switch OFF, and turning the switch to the first position, turns the low beams OFF again. The actual results of changing the power source for the fog light switch, combined with the several coding modes available, needs to be determined. Maybe someone in Europe can provide more information on the lighting functions possible with the Non US/CDN wiring configuration. Otherwise, I plan on making the wiring change soon myself.
    ** Except, the US coding provides all four parking lights ON with the turn signal lever in the Left or Right Turn position, whereas the "Rest of World" coding, the parking lights on only one side are ON with the turn signal lever switch according to if the Right Turn or Left Turn position is used.
    Jun 02 2008
    Re: Fogs with DRL's
    thanks, i have a week off around christmas so ill have time to play around with the different settings
    Please Drive Right
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Re: Fogs with DRL's
    Yes you can run ambers and fogs when you want. I have done this and here are the basic features.
    Completely off
    Ambers
    Ambers & fogs
    Ambers & headlights
    Ambers, headlights & fogs
    And you are correct, whichever setting you are in, the highbeams will come on without having an effect on anything else. I love that when I am driving down a backroad. It is literally a wall of light.
    DG '02 A4 1.8TQM
    My Build Thread
    Jun 02 2008
    Re: Fogs with DRL's
    sweet, got to find some wire and tape now
    Please Drive Right
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: Fogs with DRL's
    Before you go snipping wires, look here
    Jun 02 2008
    Re: Fogs with DRL's
    hehe ya same link i have?
    Please Drive Right
    Dec 08 2006
    Jersey
    Re: Fogs with DRL's
    Didn't notice, but you should not be in Canadian mode with that done. You have to be in Rest of the World for that to work. I have it done and did it for a few others, works flawlessly.
