Results 1 to 9 of 9
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    Angry stuck e-brake!!!!
    i never put the e-brake on snowing hard with about 5" and need to leave the office to get home. right when i sat down i realized my nightmare! any quick suggestions? just found a small hairdryer in the in the drawer. be right back...
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Dec 06 2007
    Re: stuck e-brake!!!!
    pump it a few times if no luck, u have to pull it from the rear caliper area.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Whenever my ebrake sticks, i drive with the handel down and after about 1/4 mile it releases itself. However driving in snowy conditions with a ebrake on is not smart. I reccomnd warming the car up parking it in a parking garage for a little bit if you have one.
    Mar 10 2008
    Puyallup
    pumping did nothing and i have driven a small distance in the past and it never broke it loose...
    Mar 10 2008
    Puyallup
    after two pitchers of hot water poured onto caliper and surrounding area i am able to rock the car and finally go home.
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    since its snowy, try to drift a little bit maybe it'll loosen it up
    Jun 08 2008
    Calgary AB Canada
    hot water probably wasnt a great idea... its going to end up freezing and making it worse
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by onceover View Post
    haha its so true...
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    Mine did that as soon as the temp dropped below 30 degrees out, and have not worked since, not sure why, anyone know what causes this issue sounds like a safety hazard.
