Results 1 to 13 of 13
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Question for those of you with 18"+ wheels
    Do you guys buy 5 wheels and throw one in the spare wheel well?
    What do you when you get a flat?
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    Re: Question for those of you with 18"+ wheels
    i can't speak for everyone here, but i just ordered a set of four 18" rims and i'm just gonna leave my OEM 16" as my spare. should have around the same rolling diameter if i get a flat
    two thousand two audi a-four quattro five speed
    Veteran Member Three Rings slmds4's Avatar
    Sep 22 2005
    2022 Audi SQ5
    Atlanta
    yea its not a big deal. I rode with the spare on while I went to get the tire on my 18s fixed
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    im planning on leaving my spare 17" as the spare, I could never get a solid answer if an 18" would fit in the spare tire well. But the general consensus is running a smaller diameter spare will be fine for a few miles
    My car is fast
    Active Member Two Rings cdc's Avatar
    Jan 04 2008
    Menifee, CA
    I have just used the stock 17'' when I had a flat.
    Veteran Member Four Rings Bimmerchop's Avatar
    Aug 23 2004
    2000 BMW 328i
    I have a full sized 18" CH sitting in my spare wheel well. The stock 17's wouldn't clear the stoptechs
    Quote Originally Posted by IamEzraM View Post
    an 18" wheel will fit fine. A little late, I know, lol... but at least now you know for sure
    Rich | 2001.5 EPL stg III+ TiAL 605.2 Pearl White S4 | Flickr
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | Fikse
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Stock as spare is just fine, unless you upgraded to a BBK that the stock Avus will not clear. Another thing to keep in mind is to carry a set of stock lug bolts in the kit if your aftermarket wheels uses non-stock bolts.
    Senior Member Three Rings Bee Five's Avatar
    Jun 06 2008
    Northern California
    I had my spare Fikse with a 235/40/18 tire fit in the tire well, but it's really tight. I took it out because it weighs 45lbs and I have Road Side Assistance from AAA anyways . . .
    /_/// 2000 S4 // Alcantara // Light Silver Metallic // Sport Package // 6-Speed
    APR Bi-Pipe // APR ECU // Fikse Mach V Wheels // Forged DV // JHM SS // Piggie Pipes
    ECS Stage4 BBK // RS4 Grill // SRP Pedals // ST Coilovers // UUC VM2 Exhaust // UUC Knob
    Sep 27 2007
    Columbia, SC
    Well, I guess you can always just rotate the tire if it doesn't clear the front BBK.
    THanks for the responses.
    96 Soarer GT - Gone
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Dimcorner View Post
    Eventually, if you want to, yeah get a 5th wheel spare. That way, there's no real rush to get it fixed, you can just keep the spare on and get it fixed when it's convenient. When I got a flat, I limped it home and switched to my stock wheels for a day until the new tire came in.
    08 S4- Stock SOLD
    Feb 28 2007
    S4 Stage 3+
    Las Vegas
    I'd go with an 18...
    18" B7 RS4 rep fits in the trunk... As long as the tire isn't brand new you should be fine...
    Sep 22 2005
    2022 Audi SQ5
    Atlanta
    Quote Originally Posted by Tifosi View Post
    Good advice, I forgot to mention that. I accually picked up stock lugs a few months before my tire blew luckily.
    Veteran Member Three Rings DarkcydS4's Avatar
    Jun 13 2005
    e92 335xi FBO+Meth, 2014 BMW X3 M-Sport
    Madison, WI
    I have a fifth 18" wheel that has no "protection" on it (no rubber). I actually will use it just in case I bend a wheel because the roads here in WI are so fantastic!! ::cough, cough (sarcasm):: Right now i have no spare tire in the car because the JL HighOutput Box for my w7 is massive and heavy and a pain in the a$$ to get out to try to get to the spare.
    What happens when I have a flat you ask....
    I get on my cell phone and call AAA for a tow! LoL Might as well use it, I pay for it right?
