Results 1 to 14 of 14
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    Question Griding noise around 3100 rpms, turbo going bad??
    I start hearing that after i ran straight pipes for a week, i fixed my exhaust and it still doing that. Cant really hear it before 3000 rpm and not really after 3200 rpm. sounds like some metal griding or bouncing, coming from left side of engine. Also i installed test pipe past saturday and made sure nothing was loose.
    Any ideas what it might be?
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Re: Griding noise around 3100 rpms, turbo going bad??
    Quote Originally Posted by BOPOH View Post
    Left side? Passenger or driver side?
    Probably should record it.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Oct 08 2007
    Columbus, OH
    turbo side, i'll try to get a video right now
    Jun 30 2007
    Raleigh, NC
    ^that would be passenger - aka right side. (for future reference.)
    did you get a custom exhaust made? make sure it's not rubbing on the subframe. i bottomed out my car awhile ago (bent the exhaust a little bit) and it's making the same noise in the same general RPM range. (mine is more like 4000-4200, but you get the point).
    i just cut out a section of tread from a used tire at work and tucked it around the exhaust between it and the subframe and it fixed the noise... but then when i took my turbo off the other week to change gaskets (well.. remove them) i forgot to put it back in place. lol
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Oct 08 2007
    Columbus, OH
    i just went out there with a friend to check it and record on video, but nothing would be coming out of engine bay, but i could hear it very well inside. I think you are right B6Lovin its probably my exhaust pipes, cuz i did install TP and i took off clamp for drag stip. Now clamp is back on but maybe after driving for a week it moved around so much and now making that noise from being bent somewhere.
    Dec 06 2007
    most likely is a clamp but also check ur motor mounts.
    -Kirk
    BetaAlphaTau Member #58
    Oct 08 2007
    Columbus, OH
    i tighted the clamp to where it cant go anymore, but my motor mounts are completely shot, nothing left of them :(
    Dec 06 2007
    ^^told u less than a minute before u posted, when the motor mounts are shot they make this retarded rattling noise.
    -Kirk
    Oct 08 2007
    Columbus, OH
    lol i know :) but they were shot for a LONG time now but noise started about a week ago
    Senior Member Three Rings BlaQ_B6's Avatar
    May 20 2008
    02' a4 1.8tQ
    Jersey
    Maybe its just your turbo spooling :X? Sorry to state hte obvious but, there are some people who arent familiar with what their turbo sounds like, especially after an exhaust install. Do you notice any differences in the way the car drives?
    02' A4 1.8TQ
    Clear Cornered - Blacked out Grills - Stealth bulbs - 6000K DDM HID Kit - Independent Fog Mod - Debadge
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by BlaQ_B6 View Post
    fyi, turbos don't grind. (well, they're not supposed to)
    this isn't another "why is my car whistling on accel" thread
    The Awesome™
    Oct 08 2007
    Columbus, OH
    yeah i know how my turbo sounds but i think its something else since. I had bolt loosen there on TIP that was rattling i removed it but it still making noise but you cant hear it from the engine anymore, only inside
    Jun 11 2005
    I had a resonator once that made that noise once all the baffle was burned away.
    It was only at a certain RPM too. Sounded very disturbing.
    2003 1.8T
    Oct 08 2007
    Columbus, OH
    thanks for tip i've been thinking of getting magnaflows on straight pipes
