Results 1 to 39 of 39
Thread: Twin 1 too low?
    Senior Member Three Rings therox182's Avatar
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Twin 1 too low?
    Alright so i've been looking on here about all the reviews for the Twin 1, and the general consensus is that its fucking amazing. Now the real question is, is it supposed to hang as low as I have seen in some of the pictures on here? or did those people just do a crappy job on the install? I know its going to be lower than the stock exhaust, but some of the pictures look like it would scrape on flat ground. Granted I'm at stock height, so I'd be a little higher than the majority of people on here (until I get some coilovers ), but what do those that have it have to say? Is it too low? was it just bad installs that i've seen pictures of?
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: Twin 1 too low?
    yes they hang low thats how they are made. people run them lowered so i dont see you having to many problems u just have to teach yourself hout to drive all over again lowered
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Three Rings jukesandz's Avatar
    Oct 10 2008
    '00 Audi S4
    NE
    Re: Twin 1 too low?
    Yeah, it is. I've scraped mine a couple of times, and I want to die when I hear it. I'll get some pics.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    ^^ thanks bud.
    If anyone is running a Twin 1 on stock height and has a picture of how low it hangs, i'd appreciate it
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    Re: Twin 1 too low?
    Ill get some tomorrow
    Veteran Member Four Rings Aggv's Avatar
    Sep 26 2006
    Ohio
    Re: Twin 1 too low?
    i have a twin2, same thing just an extra muffler and im on H&R springs and it will scrap from time to time. That's just how it's suppose to be so yea, learn to drive different
    S4
    Senior Member Three Rings theboogieman1's Avatar
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Re: Twin 1 too low?
    Yeah, I have the SSAutoChrome (based off the Twin2) and I would scrap at stock height on big speed bumps with a few people in the car. Now my car is lowered I hit it quite often, so I have to learn how to drive with it. I do need to raise my car up a bit more cause I'm sitting at 24 3/4 all around. Thinking of bringing it up to about 25 1/4 to see if I can handle that. Right now I'm having trouble with minor speed bumps. I'll try and take some shots of mine as well tonight.
    02' Black S4 6spd / JHM "Stage 3" / JHM "Solid" Shifter / VAST Stg. 3 Clutch and LW Flywheel / Vogtland GT's / 034 Track Density Motor Mounts/ AWE DTS / JHM FMIC / Hawk HPS Pads / H-sport sways / SSAutochrome TB Exhaust
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    thanks guys, i appreciate it. The Twin 1 is already on its way, so I guess i'll just have to adjust the driving style once its on.
    Mar 12 2008
    B8.5 S4
    San Jose, CA
    Re: Twin 1 too low?
    i got it too and it hangs low but its worth it
    cus it sounds amazing
    2015 Audi S4
    2007 Audi RS4
    2002 Audi S4
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Twin 1 too low?
    here's my twin one, back when I had a cup kit, H&R springs/Bilstein shocks. I couldn't make it down my own driveway! Thing was 1.5 inches from the ground, now I'm on H&R coilovers and 18 inch wheels and with one or two people I can make it down my driveway but with 3 or 4 I will scrape the nuts on the hanger.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    ^ g-zus thats low
    how much space do you think i'll have on stock height?
    Veteran Member Three Rings Number54's Avatar
    Dec 04 2007
    Switzerland
    Re: Twin 1 too low?
    Yeah, I run the Twin1 and it definitely hangs low. But the fitment is really quite good. There's a pic in my pictureposter: http://pictureposter.audiworld.com/1...ontowtruck.jpg. That's with STaSIS Tracksport coilovers.
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Re: Twin 1 too low?
    So this is the only picture I have for now, I couldn't get out to snap some pics tonight but you can see it angle down towards the rear tire. Also I think the clamp in the middle is the thing that's scraping so I need to see if that can be rotated so the bolts aren't facing down.
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    Re: Twin 1 too low?
    i am on stasis coilovers and 18 inch wheels.. and it hangs very low.. i scrape over some driveways and stuff but just as much as my front end will scrape also... if your low and go too fast over anything you will scrape something. If you are stock ride height dont worry about it. Twin 1 is fine at stock height.
    It looks very nice with the pipes hanging low IMO :)
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Twin 1 too low?
    my buddy had a noggy s4 before his friend totalled it, and at stock height he would still scrape, but as others have said, its the clamp right after the DP's that scrape, if that could be rotated, i would think you'd be OK, but I'm not sure if you'd want to do that as it's kind of a guard from scraping the hell out of the piping. I'd rather scrape some nuts and bolts than the pipes!
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    hahah, you'd rather scrape nuts
    Veteran Member Four Rings CruzS4's Avatar
    Mar 01 2007
    WK2
    Conshohocken/Sea Isle
    Re: Twin 1 too low?
    my ride height is at 25.5 on all corners and i have yet to scrape my twin1 on anything. granted i take speed bumps and driveways pretty slow
    here's a few pics i dragged my lazy ass outside to take, sorry for the crappy low res point and shoot. (I know pics 2 and 3 bear no relevance to exhaust height)
    '17 Ibis White B9 A4 quattro P+ S-Line
    Oct 10 2008
    '00 Audi S4
    NE
    Re: Twin 1 too low?
    Dammit I forgot my USB thing to put pics from the camera onto my comp. Here's a camera phone pic which probably doesn't help at all.
    Honestly though, when I look at it, I agree with what AudiSportB5 S4 said. When the stock exhaust was on there, the clamps were turned so the nuts and bolts were up, but I left the clamps (with my new non-rusted-pieces-of-shit nuts and bolts) down with the Twin1 just to make it easier to get to. Most likely, this is what scrapes. It never scrapes on speed bumps, it only on reeeeally steep humps.
    It's not a main concern of mine. I wouldn't not get the Twin1 just because of that. It DOES sound amazing:
    http://www.youtube.com/watch?v=xA5VCzAHqWU
    Deactivated Four Rings
    Apr 09 2008
    Willow Grove, PA
    Re: Twin 1 too low?
    If installed correctly the Twin1 and Twin2 will hang no lower than the lowest point of the car.
    Anyone with a lowered car, regardless of make/model, should approach speed bumps and inclines with more caution.
    If you guys are having scraping issues I would double check to make sure it's installed properly.
    If you have the clamps turned down, check them out as well. It could be the source of the scraping.
    Registered Member Two Rings s2000_s4_525's Avatar
    Apr 25 2007
    B5 S4 stage 3+++/ Turbo s2000
    Canada, British Columbia
    Re: Twin 1 too low?
    Sigh you should see me uuc Its TRASHED, it hangs very extreamly low. It has a huge dent aprox 1 foot long and a leak. I need a new one. sigh
    Stage 3 s4 Wicked Motorsports... / S2000 turbo/ Soon to expand....
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Re: Twin 1 too low?
    Hey Mike,
    I have sent you several PM's and an email about that cover......have you gotten any of them?
    Don't mean to bug you, but I have no clue if you still have it or not as I haven't heard anything from you....
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Registered Member Two Rings i5wikcedi3's Avatar
    Oct 05 2008
    2001 Audi S4 Stage 2+
    San Diego
    Re: Twin 1 too low?
    I have a Twin 2 system, on Stasis track/sports and it doesn't hang low at all. Looks pretty damn stock on mine. No scrapes at all. Only thing I hit is my AWE stabilizer bar on speed bumps. Pretty f'in sweeet I tell ya. Might do a mid muffler delete soon, Twin 2 is a bit too quiet for me.
    "Fear No EVO"
    GIAC Chip, AWE DP's w/ hiflow cats, AWE Twin 2 system, AWE DTS, AWE Boost Gauge, APR Bi pipe, EVO intake, 710N DV's, STaSIS T/S Suspension, Short Shifter, Euro headlights, RS4 clutch kit, 11 lb Fidanza flywheel, PowerStop D/S Rotors
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Re: Twin 1 too low?
    Quote Originally Posted by i5wikcedi3 View Post
    Do you have any pics? Curious to see how low your car is and see how the system hangs underneath. My system scraps very easily on small speed bumps.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    so does this mean everyone is just installing it incorrectly??
    Alex/A.W.E, do you have any pictures of what it should look like? thatd be sweet. (btw, just got my Twin 1 in today, you guys are awesome!)
    Oct 05 2008
    San Diego
    Re: Twin 1 too low?
    I'll pm you some pics once I take them.
    "Fear No EVO"
    Jan 08 2007
    02 Audi S4
    Pacifica, CA
    Re: Twin 1 too low?
    So I just had my clamp adjusted so the bolts aren't face down and so far so good on the scraping. I have gone over bigger speed bumps without a problem. I have a few pics that I'll try and post later but the clearance seems good now.
    Feb 12 2008
    01' S4/ 98' Boxster
    Lake Oswego/Corvallis
    Re: Twin 1 too low?
    So whats your guys suggestions on Fender to Ground for the twin 1? I just ordered one and am about my coilovers along with an alignment when i put it on. I am at about 24.75" right now on 18" DTM RS4 (225/40/18) I have a fairly steep driveway so i don't wanna scrape on the way up then back down ( it peaks like this ^ so i barely miss hitting the middle of my car everytime and i am scared that after putting on the twin 1 i will scrape so thats why i wanna raise it.)
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    thanks guys i appreciate it. hopefully within two weeks i'll be able to post my clearance
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    Alright well I just got the Twin 1 put on and the sound is pure sex. It's awesome. And considering i'm on stock suspension, it hangs fine. Not low at all. I doubt i will even have to change driving habits until i drop the car. The way it hangs now, i feel like youd have to be SLAMMED for it to really cause a problem or anything.
    It does hang kinda crooked though. Up and off to the right. The mechanic who put it on (works at Jack Daniels Audi and has put multiple twin 1's on) said that its never 100% straight and he played with it for a while to try and get it as best he could. Its actually touching the bumper a little bit. I was just curious if everyone else has had this issue. You'd probably only notice it if you were looking at it for that reason, otherwise its not that big of a deal. But i know, and it bothers me.
    Mar 22 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    Re: Twin 1 too low?
    Quote Originally Posted by therox182 View Post
    I just installed my twin 2 last weekend... fitment is perfect. Tips are perfectly lined up in the bumper (doesn't hang weird and it isn't touching one side or the other). Fitment was great under the car too . It's not touching any heat shield or any part of the subframe... Maybe Jack Daniels should learn to install and adjust exhausts? I'm not sure what's so difficult about it, I had 0 problems.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    hmmm well it looks like i have a bone to pick with my mechanic. he'll be getting a call tomorrow morning
    Mar 01 2007
    WK2
    Re: Twin 1 too low?
    funny, my car originally came from jack daniels audi. i wouldn't worry too much if the fitment isn't absolutely perfect. my tips list a little to the left as you can see from my post above from weeks ago. sound is awesome though, screams at wot
    Stage 2 Banner Advertiser Three Rings Todd/AWE's Avatar
    Mar 19 2004
    Willow Grove, PA
    Re: Twin 1 too low?
    Glad to read that you are satisfied.
    Regarding Twin1 tips: since there is no rear muffler, sometimes the tailpipes can get misaligned during the shipping process. It is easy to fix. Just grab the two tips and push up or down on the one that is too high or too low. The bracket that holds the two pipes together can bend a few mm with not much muscle effort. Quick and easy to fix and it will stay that way.
    Todd Sager > President
    AWE-Tuning.com > 1.888.565.2257
    facebook > twitter > YouTube
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Re: Twin 1 too low?
    Quote Originally Posted by Todd/A.W.E. View Post
    i'll give that a shot today. thanks
    Veteran Member Four Rings Yesmar's Avatar
    May 15 2009
    couple 2.7t's, and a tacoma
    Harrisburg, PA
    Re: Twin 1 too low?
    x2 thank you
    Mar 21 2008
    Re: Twin 1 too low?
    does the twin 1 come with the exhaust gaskets???
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Re: Twin 1 too low?
    Quote Originally Posted by looseboost View Post
    holy bump, jesus christ.
    Mar 21 2008
    Re: Twin 1 too low?
    what u want me to make a new thread for such a simple question?
    Senior Member Two Rings klhbeetle's Avatar
    Sep 15 2008
    Santa Fe
    Re: Twin 1 too low?
    My twin II came with nothing. You reuse your stock sleeve clamps.
    '01 allroad 6mt stage3
    '08 Ford E350 Quigley 4x4 Powerstroke
