Results 1 to 16 of 16
    Nov 22 2008
    01.5 S4
    Michigan
    (PIC)Does Anyone Know what Wire this is
    just getting ready to clean my car and i found this wire hanging out...does this have anything to do with the dashboards lights?
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: (PIC)Does Anyone Know what Wire this is
    do you have a remote starter? why dont you follow it until it gets to something
    Nov 22 2008
    01.5 S4
    Michigan
    no i dont have a remote starter...i will when i have some time i guess some one here knew what that wire is...
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    if theres nothing wrong with your car just tuck that shit back in behind the radio
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Nov 22 2008
    01.5 S4
    Michigan
    yeah there is my radio lights dont work and i have a damn fuse and battery light i keep changing the fuse and just keeps popping
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    that wire is aftermarket... the factory wiring int he car is wrapped in black material tape... thats def an aftermarket electronic of some sort... likely the source of your blown fuses
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Nov 13 2007
    B5 S4 Avant
    Boston
    ^thats why i asked if there was a remote start,it looks like the antenna wire for it...
    follow the wire
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    Quote Originally Posted by EuroSteez View Post
    Not to thread jack but can you can a remote starter without getting an aftermarket alarm?
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    yes you can just buy a starter without an alarm. OP, that definately looks like an aftermarket wire to me. do you have any aftermarket audio equipment in your car? in the trunk still using the factory headunit? I agree with an earlier post, it looks like an antenna wire for an alarm or starter. Also a remote gain control for some amps that may have been used in the trunk at one time. Mine had one when i bought it. I got digging around and behind the trunk liner was a legacy 3 way crossover with a remote gain.... not hooked up just laying there.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    could also be a wire for a sub setup. Although the gauge of it looks small.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Nov 25 2008
    looks like an ethernet cable to me, cat 5 maybe 5e or 6. could have been used for Vag-com
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Get those radio keys out and do some digging.
    Veteran Member Three Rings 2BblkAudis's Avatar
    Feb 15 2007
    San Mateo, CA
    Looks very similar to my Valentine 1 Radar detector hard wire or remote display wire. The V1 uses basically a telephone cable. Drop the panel down and see what you have going on under your dash. It's very possible that a splice or tap may be the cause of your short.
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    Is it the wire that goes into the center arm rest for the cat jack???
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Nov 22 2008
    01.5 S4
    Michigan
    shit thanks alot guys im gonna check it out when i got some time i hope its the reason my damn fuse light keeps going on and my car has no voltz whats so ever
    Nov 22 2008
    01.5 S4
    Michigan
    obijohn22 where you the guy that was at mive show last summer lol i member your car by the wheels and the wing
