Results 1 to 16 of 16
    Nov 10 2006
    B7 A4
    Detroit Michigan
    AEB motor question.
    Whats the difference between and automatic and a manual motor? I popped my motor last night and trying to make sure i get the correct one my car is a manual
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: AEB motor question.
    crankshaft is diffrent
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Hmmmm looks like we have both auto and 5-speed motors available :-D
    http://www.audizine.com/forum/showthread.php?t=249973
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    popped your engine? Sounds bad, you want to get rid of it for cheap? What's the damage?
    Nov 10 2006
    B7 A4
    Detroit Michigan
    connecting rod threw the side of the block i believe. I got an engine already lined up to buy. but not sure if its auto or manual. It should be no problem to find a good crank though.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    well considering you threw a rod I would HOPE that your going to build the motor this time.. unless ur not making the power and ur just guessing as to what happened.
    Jun 04 2007
    atlanta GA
    how exactly did you throw a rod? I've seen the AEB handle massive power unbuilt so i'm just wondering what you were runnin?
    oh and i don't think there's two different motors for AT/MT....but i think these other guys know a lot better than me.
    Oct 01 2008
    Philly
    No. The crankshaft is different. And unless your considering building the motor i would not buy an auto motor, as the manual's are pretty available.
    Jun 04 2007
    atlanta GA
    oh ok. is it just different at the flywheel end? I've never noticed the difference but then again i never looked for one. I'm just curious about it. thanks
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    The difference is in the bolt pattern. It's completely different for the automatic/Tiptronic cars as it is for the manual trans cars.
    Offer still stands. If you want to get that freshly opened up engine assembly out of your garage I'll pay you for it. My interest depends on the price though.
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Quote Originally Posted by njm23 View Post
    Im building the motor, my motor was on is way out and I kinda just finished it off. Im positive a rod is snapped cause I was doing a third gear pull logging, and then the oil level light came on and the car died. Pulled the dipstick out hardly any oil in it and the car wouldnt turn over cause the rod is probably wedged between the block and crank. Im going to visit the junk yard payday, to see if i can pick up a rebuildable core. Can I eyeball it and tell if it is an auto or manual?
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Quote Originally Posted by djwimbo View Post
    Well here is the deal im pretty much broke until taxes come back. Depending what my next few checks look like and if i can line up somewhere to pull it ill contact you. What do you need off of the engine? Hmm my question is to you, what can you use off of and engine the snapped a rod. The head is probably toast, the block is toast and the crank who knows what the deal is with that. But hey, if you can use something that i dont need its yours. :)
    Senior Member Two Rings safab's Avatar
    Apr 25 2007
    ca
    I've got a AEB 5spd crank that I'm not using anymore...PM if you need it.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by turbo944s2 View Post
    Well here is the deal im pretty much broke until taxes come back. Depending what my next few checks look like and if i can line up somewhere to pull it ill contact you...
    I don't own a cherry picker, but if you need a hand I'd be willing to help out. I know I'm not in the Detroit area, but I'm sure we can work something out, if you need a hand and have a place to yank it.
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Hey thanks for the offer, that is very nice of you. What parts do you need off of the junk motor? I have another motor lined up all im interested in is the block and head. All the rest of the stuff will be replaced (factory pistons, rods, crank).
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    to be entirely honest the head is the money maker. I wasn't sure what you needed off the original block, or what comes with the spare one you're swapping in. Feel free to PM me when the time comes for the swap, I'm more than willing to take some spare parts off your hands if you need some help.
    I'm just a broke ass college student that could use some spare cash on the side, I was a tech for >3yrs, I'm just going a different route with the next degree.
