We've been cleaning out the mezzanines of our shop a bit and have found some tasty goodies laying around. Below is a list of what we have. We're accepting reasonable offers on everything.
If you're interested in something, I'm happy to snap more pics for you. Feel free to send me an email.
NEW ITEMS
-Innovative Turbo Systems T04E 57 trim turbo, .58 A/R; O wheel; wet(oil and water cooled); 3” inlet; tangential; divided housing; v-band discharge. X 2
$995 retail. $590 special
-Dahlback Racing longitudinal/transverse 1.8T cast exhaust manifold w/ external wastegate
$1400
-Matrix/Forge A4 Challenge intercooler; 25" wide x 11.8" high x 2.4" thick; 2.5" inlet & 3" outlet
$795 retail. $500 special.
-6-into-1 Merge Collector; 1.75" x .049 (15deg); 2.50" OD throat; mild steel
$605 retail. $419 special
-Flowmaster 50 Series Performance Muffler; Dual 2.25" in/out; 10" wide; 17" case length
$140 retail. $80 special
-81mm 8.5:1 CR JE piston set; for 1.8L 16V w/ 2.0L 16V(9A) head; w/ rings, wire locks, fitted 22mm pins
$599 retail. $389 special
81mm 8.5:1 CR JE piston set; for 1.8L 16V; w/ rings, wire locks, and fitted 22mm pins.
-83mm 8:1 CR JE piston set; for 16V; suggested for use with 1.6L crank; w/ Total Seal ring package, wire locks, fitted 22mm pins—we recommend running these at .004” clearance
$799 retail. $589 special
83mm 8:1 CR JE piston set; for 16V; suggested for use with 1.6L crank; w/ Total Seal ring package, wire locks, and fitted 22mm pins.
We recommend running these at .004” clearance.
-Mahle 3.0L VR6 piston set; 8.5:1 CR; w/ pins and wire locks
$1395 retail. $750 special
-Raceware 10mm VW/Audi 1.8T 20V head stud kit; for most B5 incl AWM and B6, VW AWP, Audi AMU?
$309 retail. $225 special
-ARP VR6 head stud kit
$226 retail. $145 special
-HyperBoost HX Acid Blue Anodized Diverter Valve
$159.99 retail. $100 special.
-Matrix 99 or 00MAF Housing. Lots of them.
$75 retail. $30 special
-TWM 48mmx90mmx88mm air horn spinning x 8.
$35/ea retail. $20/ea special
-TEC 3R Unterminated wiring harness; 23-pin Connectors Only, with 6ft of wire; w/ cable and connector for TPS 71310, 71330, and 71350
$210 retail. $120 special
-M&W Pro-12 2 channel ignition(4cyl)—for use with Autronic stand alone
$575 retail. $300 special
-Stack ST8130P Street Dash Plus; 0-3-10,500rpms
$1500 retail. $1100 special
-APEX'I 60mm Electronic Boost Gauge
$325 retail. $200 special
-AP 3 plate gear drive clutch
$2100 retail. $Offer
-Wilwood Dual Pedal Assy setup, with AP Racing 5" Tall Reservoir .4375(7/16) Mnt. X 3, Girling master Cyl; .75 Remote, 1 for front brakes; 1 for rear brakes; Girling master Cyl; 5/8(.625) for clutch
$567 retail. $379 special
-STaSIS TrackSport 14.5" Mono4 front brake kit for A3/Mk5 (incl R32); 2 Alcon Monobloc 4-piston calipers, 2 14.5" x 28mm Alcon directionally vented/gas slotted floating rotors, 2 STaSIS directionally vented mounting hats, 2 STaSIS caliper mounting brackets, SBS Pro-Intermediate/Track high performance brake pads, Goodridge braided/coated stainless steel brake lines (front only), Motul 5.1 high performance brake fluid
$3395 retail. $2695 special.
-Tie rod assembly for Mk1 w/ manual steering; #171-419-804 x 2
$120/ea retail. $20 special
-11.3" Zimmerman x-drilled front rotor for G/J/P VR6 '96-98
$135/ea retail. $63/ea special
-9.1" (x9mm) Brembo solid rear rotor for Mk4/NB/TT FWD;
$45/each retail. $18/ea special
-9.6" Hawk HPS (street) rear pad set for Audi A4 Quattro; #HB271.F605 (2 available)
$83.50 retail. $64 special
-Hawk HPS Plus (street/track) rear pad set for E46 M3/M5/E38 740il/X3/X5/330
$99.48 retail. $70 special
-Rear “Enduro” brake shoe set for Mk1 Rabbit
$26 retail. $10 special
-Bugpack Mk1 polyurethane upper strut bushing set
$Offer
-ABT-copy wide body kit for Mk3 Golf; rear fenders only!
Brand new, never used.
$1499/kit retail. $300/set special
-SPA right/left hand convex side mirror set; black
$120 retail. $80 special
-Schroth Rallye 4 Quick-Fit street harness for most VW/Audi incl B7, except B6; left side; red
$315 retail. $245 special
USED ITEMS
-Stock “AEB” 1.8T long block w/ 50k
$Offer
-1803cc 1.8T short block w/ 81.5mm Wiseco piston set (9:1 CR, 20mm pins), Arrow Precision connecting rods(144mm length), Raceware 11mm head stud kit
$Offer
-Electromotive TEC3 setup from our B5 A4 racecar(now Issam's 034 monster)
$Offer
-Innovative Turbo GT58 dual ball bearing/P Trim/0.58 A/R/Tang/V-Band Discharge/undivided/Wet/Dynamic Seal setup with custom hand-built SS304 manifold, twin TiAL 35mm high pressure red wastegates w/ 0.95bar springs, red TiAL 50mm BOV, 3.5" driver side-dump v-band'd exhaust with tiny Random Technology cat and Burns ultralight 12" SS muffler
$Offer
-Matrix/Forge Mk4 VR6 Turbo FMIC; core w/ endtanks only; core is 25.5" W x 7" H; 2" inlet/outlet
$750 retail. $460 special
-Davies Craig Electric Water Pump; 12V 90W; with controller
$500 retail. $290 special
-TurboXS blowoff valve
$Offer
-Bunch of used turbos (B5 S4, Golf 1.8T, TT225)
$Offer
-K&N filter for Mk3 VR6/8V
$20
-12V VR6 upper intake manifold x 3
$60
-12V VR6 upper intake manifold (modified for better flow) x 1
$125
-12V VR6 lower intake manifold x 2
$45
-12V VR6 exhaust manifold sets x 4
$150
-16V upper intake manifold x 4
$50
-16V lower intake manifold x 3
$40
-16V exhaust manifold x 2
$60
-Mk2 dual outlet exhaust manifold x 2
$90
-B5 A4 1.8T SMIC w/ intake duct x 2 (058-145-805-A, 058-145-805-C)
$70
-Mk4 1.8T SMIC w/ intake duct
$70
-Stock Mk4 R32 engine mounts
$Offer
-B5 S4 fuel injectors (set of 6) x 2
$Offer
-Mk4 R32 fuel injectors (set of 6)
$Offer
-Mk4 1.8T/TT 1.8T fuel injectors (set of 4)
$Offer
-B5 S4 “HP2” front caliper set x 3
$200
-ABS controller setup w/ wiring for ’92 Corrado VR6 w/ ABS and EDL
$175
-H&R sport spring set for Mk3
$100 special
-Bilstein PSS9 coilover kit for 996TT; 9way adj. ~500 miles on them—client went with Moton’s.
$3600 retail. $2000 special
-H&R cup kit for Mk4; #31017
$400
-H&R rear coilover pair for Mk2/3; one with broken top stud
$100
-Eibach front stressbar for Mk3; polished aluminum
$40
-Early VR6 spindle set
$Offer
-Early Mk3 8V? spindle set
$Offer
-Bunch of used trannies
$Offer
-Bunch of used axles
$Offer
-Front/rear A!Avant Garde Type-S bumper set for B5, silver. Bodywork done twice to get them smooth. Rear needs to be repainted.
$900 + S&H
-B5 A4 xenon e-code set (no ballasts)
$400
-Jetta3 rear spoiler; forest green
$Offer
-’99 Passat 1.8T f/r bumpers, doors, hood, hatch, LF fender, leather interior, dash, headliner, etc
-DJ Auto 7” round headlights w/ crosshairs for Mk2
$60 offer
-Carbon fiber/Kevlar? radiator trim cover for Mk3 VR6
$Offer
-AudioControl EQX electronic crossover
$Offer
-B5 center console; black
$Offer
