I'm about to go through and order everything I need for the 55k service, plus a little bit more through ECS for the S4, and was just wondering about some quantities.
1) Oil: I'm going with Lubro Moly through this site, at 10 liters from what I Understand: http://www.eurosportacc.com/liquimol...nthese_oil.htm
2)Trans: I was going to go with the Redline MT-90 ES#1503, and I thought I read from what someone had posted, it took about exactly 1 gallon, so 4 quarts of it from ECS. (Quantity???)
3) Diffs: I was also going to use Redline 75W/90 for the differentials. I was wondering how much I'll need though, and how difficult it is to do, or any other information needed. (Quantity???)
4) Spark Plugs: I went with oem bosch spark plugs from ECS, the set of 8 ES#4539.
5) Also I got replacement filters such as: Mann - Fuel Filter ES#4998, Hengst - Oil Filter Kit ES#3549, Meyle - Cabin Filter / Fresh Air Filter (300x205x30) Charcoal Lined ES#248463
6)And finally getting the Bently Repair / Service Manual On CD ES#6277, I've been meaning to order it for a while, hadn't gotten around to it.
I already have a hexcan vagcomm cable so I shouldn't have any problems resetting any of the service info. This is the first real major service I've done on the S, (since it's been under warranty up to now and I got it at 39k) so I figured that I'd do everything I'd feel comfortable with, and then have my local shop do anything else that is mentioned in the Bently manual service intervals.
Finally I was looking into using this http://www.amazon.com/Mityvac-7201-F...8&s=automotive to do the oil change as several have mentioned using such a setup, and that it has good reviews. However, I was wondering if the tank is large enough to contain all the oil in one cycle, or if it would take more than one pass to remove all the oil.
Any other suggestion, ideas, tips, or points of interest would be greatly appreciated on the matter. I'm looking forward to getting it all done and knowing that my car is in tip top shape. I feel pretty comfortable with tools, and have already gone exploring in the audi a fair bit, but nothing too serious. Thanks guys, I appreciate the help as always! ! !
